I get the feeling you do not understand the properties of a telephoto lens judging by your last question below.
"BTW: Why would shorter shutter speeds (even shorter than 1/4000) be required to stop
subject motion with "extreme telephoto lengths" than with shorter focal lengths?"
So here is something I'm sure you will understand.
If you hand hold your camera/lens combo and take a photo of a small bird imobile at 25 feet distance with a 24mm lens at f/5.6 and ISO 100 using shutter speed of 1/100 sec. lens you will not see blur.
Now switch out your lens to an 800mm f/5.6 supertelephoto (OIS set to off), have the camera settings the exact same, f/5.6, ISO 100, Tv 1/100 and take another picture of the same imobile bird still 25 feet away while hand holding the camera/lens combo. The entire image will show blur, the grass and the bird. Ask yourself how could this be?
Think on what changes you made and how that change effect image sharpness.
Hint: what are the properties of an supertelepho 800mm lens and what are the properties of a 24mm wide angle lens?
If you are unable to figure this out I suggest you read up on it.
I really hope you do some reading as it's no supprise to me how many uneducated in photography consumers belong to this web site.
You are not alone, you fit the dpr mold very well.
-Peter
Subject movement is the culprit more times than not. IS does nothing for subject movement. Sometimes even 1/4000 of a second isn't enough at the extreme telephoto lengths the GH2 can obtain.
IS is not a cure all. In fact most of the time it really isn't helping you at all.
I think most of us are already well aware that camera shake is not the only source of blur. Nevertheless, I strongly disagree with what you say. Unless you are a dedicated action shooter or carry a tripod wherever you go, camera shake is a very significant source of blur, and IS helps a lot (provided it works as intended). It is particularly helpful for long teles where camera shake rather than subject motion often determines how far down you can go in terms of shutter speed.
Life as an artist has had some unusual times to say the least.
visit my web site
http://www.flickr.com/photos/artist_eyes/
Remember to click on 'All Sizes' for better viewing.
Artist Eyes
