luisflorit
Interesting. Never thought in this way, but it does make perfect sense.If you do 100% pixel-peeping you are effectively using digital zoom, which means an increase of the crop-factor. For example if you watch a picture from the GH2 on a FullHD-screen at 100% you get an effective focal-length of about 1600mm, so your rule of thumb results in a necessary shutter speed of 1/1600s, not 1/600s.
You bet!And 1/500s then will be about 2 stops too slow, and this is what you can expect from an IS-system, but not much more (I know manufacturers like to tell you 4 stops or even more improvement, but in reality no IS-system will give you much more than 2 stops)
This is not the problem. The E3 and the FZ50 have identical resolution (10MP). The E5 a bit more (12MP), but not enough to compensate for the much smaller FL. It is actually the opposite, the FZ50+TCON gives you more 'digital zoom', as you called it.I also doubt you compared them correct, which would mean at the same output-size. The lower resolution of the FZ50 means images will look sharper when they are viewed at 100%.
I never use the flash as main source of light, because wildlife pictures come out horrible. I always try to hide it as much as I can.When the flash is the main-exposure the shutter-speed is irrelevant. You could shoot at 1/10s and the image still will be sharp. When light-levels are low and you use the flash exposure isn´t influenced (significantly) by the shutter-speed, the flash makes the exposure and it is very fast (estimated about 1/10000s)
Of course.A IS-system always can just react. So with shutter-speeds where camera-shake becomes significant there will always be some blurring. IS will decrease this blurring but it will not prevent it completely.
Yep. All wildlife shooters have learned the hard way that you always need to take as many pictures as you can.Camera-shake will also be different in each photo, and an IS-system will increase your rate of usable photos, but it will never guarantee it, so in critical situations it is always best to shoot more pictures.
Thanks!
L.
My gallery: http://luis.impa.br/photos
Oly E5 + E3 + 12-60 + 50-200 + EC14 + FL50R
Pany FZ50 + Oly FL50 + TCON17 + Raynox 150 & 250
