luisflorit
Hi folks,
I am a wildlife shooter seriously considering switching from Oly 43rds to Pany m43rds. As such, the GH2+100-300 is my absolute first combo of choice. I am interested in handholdable lenses only, since I walk hours in rainforests and tripods are not practical.
However, I've seen many times people complaining about the 100-300 OIS, saying that even at 1/500s you get blurry shots (when handholding of course). For example, in this review:
http://www.photographyblog.com/reviews/panasonic_lumix_g_vario_100_300mm_f4_56_mega_ois_review/conclusion/
This sounds pretty strange to me. The rule of thumb says that, at 600mm EFL, you should get sharp results at 1/600s without any stabilization. I use(d) my old Pany FZ50+TCON17 (714mm EFL) at 1/250s without any problem. I use E5 + 50-200 + EC14 at 560mm EFL @1/250s, although less reliably than the FZ50, still Ok. Yes, I found the FZ50 stabilization way more reliable than the Oly """"""pro"""""" setup, even at longer focal lengths (!!!?).
Then, how can the 100-300 OIS be so much worse than an old P&S of the same brand?
And there is another issue. As you read above, I wrote several times 1/250s. This number is important, since it is the fastest flash sync of all my cameas. In rainforests, with a non FF camera, flash is a must. But the GH2 has flash sync of 1/160s ($%%#@$#^!!!!), so I should have to shoot at 600mm EFL and 1/160s, with flash...
So, I want your opinion on the OIS of the 100-300. As you can see, it would be a killer for me if not really good (2 stops at least).
Thanks!
L.
My gallery: http://luis.impa.br/photos
Oly E5 + E3 + 12-60 + 50-200 + EC14 + FL50R
Pany FZ50 + Oly FL50 + TCON17 + Raynox 150 & 250
Thanks!
L.
