bayoubooger
Active member
Anything But Canon, you fools ROCK? On the wrong forum?
Oh you have an SX210? With no attachments, it does about as well as the S95 (that is, about average). Paired with a DCR-250 the SX210 would really excel because it has a long telephoto setting, BUT there is one problem: The SX210 does not support lens adapters. You would have to buy one that attaches to the tripod mount underneath the camera. I have one of these, and although not ideal it does work.My other question is will the s95, G12, SD4000 etc give me noticeably better results than my SX210is? I find that doesn't focus close enough, but i guess that's where the DCR-250 comes in...right?
Precisely, the S95 will give you nearly identical macro photos to what you can already get.ok, so if i want a material increase in PQ then S95 over SX210is isn;t going to work, perhaps the reality for a published book, i am going to need to bite the bullet and get an SLR, with gubbins...
What issues do you find with the photos so far? That might help us with the suggestions.I also need non macro shots of the whole watch, Showing detail and little noise over a wider area than macro. Max shots in the book would be 8x 6 inches with many quarter page detail shots. Im not convinced for the non macro shots the sx210is is good enough from my results so far.
People rave about those cameras because they are really good at normal shooting (which is the highest priority for most people), and they are decent at taking shots of small things. They usually aren't trying to take extreme closeups of tiny objects as you are.Why do people rave about S95 and LX5 and micro SLRs if they do not take better materially better shots than the SX210is at this size?
I can vouch for this as well. Works great.OK, then. Have you thought about using the reverse lens macro technique to get THAT intimate close-up images? A DSLR setup with a affordable 50mm prime would achieve that effect for you. See the link:
http://www.digital-photography-school.com/reverse-mounting-your-prime-lenses-for-affordable-macro-photography
