sharksnacks
Member
- Messages
- 27
- Reaction score
- 3
Who makes the best lenses? Is it more important to invest in a company with the best lenses, or the best cameras?
--Who makes the best lenses? Is it more important to invest in a company with the best lenses, or the best cameras?
This is something I've always thought. If an old lens is tack sharp in the center, but a little soft on the edges, as many 35mm/FF lenses are, they should actually preform better on cropped sensors, because those soft edges would be outside the image coverage. Right?What adds to the complexity is that sometime lenses designed for FF perform better on the crop than they do on the FF body. Because they cut out the edge performance of the lens and just get the sweet center of the lens which in some lenses perform better. Hmmmm
Darkness is the monster and your shutter is your sword, aperture your shield and iso your armor. Strike fast with your sword and defend well with your shield and hope your armor holds up.
Richard,I shoot with Nikon D700 full frame bodies and Nikkor lenses. I have been gradually replacing my legacy D glass with new G lenses because the D lenses were designed for film, and those designs are not usually the best for digital because the light receiving angle of film is much wider than that for a digital sensor. On digital, the best lenses (meaning the really good lenses) are designed for digital. That is what motivated Olympus to stop design its E series of gear that is all digital in design. Canon and Nikon stayed hybrid but have gradually been replacing their film lenses with digital designs, which of course cost more. Quality has its price.
In addition to the above, adding a micro-lens array above the photosites further constrains the acceptance angle. Even if the micro-lenses are offset at the edges, the acceptance angle is the same...just pointed in a different direction.Film has the most sensitivity at its surface and has always been thought of as a flat 2-dimensional sensor. A digital sensor composed of millions of photosites (incorrectly called "pixels"), has a 3-dimensional aspect in sensitivity.
Photosites are like microscopic wells that get filled with light and respond with an analog voltage signal (that's right, the data is not digital at this stage). Light coming down into the photosite well in a straight line from the center of the lens gives the maximum voltage signal. The more the light ray diverges from the center, the less response you get from the photosite.
Think of it as holding a water hose straight over a bucket compared to one spraying into a bucket from the side. Obviously the side spray will take longer to fill the bucket because a lot of the water sprays past it hitting the side.
Zeiss and Sony conspired to produce the R1 a full year before the M8. The R1 had the back lens element about 1.5mm from the sensor. Go read reviews about how well it worked.While the divergence of light rays from the back of a lens had a small impact on film's relatively flat sensitised layer's response to the light, the well structure of a digital sensor made that impact quite obvious. It was much easier to keep the sensors' edge limits closer to the center (i.e. smaller sensors) to solve this problem than to reformulate the optics to provide more parallel (and perpendicular to the sensor) light rays. Some manufacturers eventually designed special lenses with a smaller image circle to cover the digital sensors more evenly (like Olympus' 4/3 or Nikon's DX series), but photographers wanted their cameras with full 35mm sensors and the search for solutions continued.
Up until the Leica M8 was released, engineers said a digital rangefinder Leica was technically "impossible" due to the proximity of the focal plane (sensor) to the rear of the lens, which is much shorter than in an SLR. The rangefinder lenses would have light striking the sensor at such extreme angles toward the edges, that they could not compensate for it with the availble Leica lenses. Leica and Kodak worked out a sensor with gradually offset lenses over the photosites that directed the light striking them down into the photosite "buckets."
The purpose of the offset microlenses is not to constrain the acceptance angle, but to redirect the diverging light rays down into the photosite wells, but I think we are saying the same thing here...In addition to the above, adding a micro-lens array above the photosites further constrains the acceptance angle. Even if the micro-lenses are offset at the edges, the acceptance angle is the same...just pointed in a different direction.
You are forgetting some very important differences between Leica's M8 and Sony's R1. The R1 has a smaller 21.5 x 14.4 mm CMOS sensor than the M8's 27 x 18 CCD (smaller image circle is easier to correct for diverging light rays), and most important, the Zeiss lens is dedicated to that sensor and NOT interchangeable! I am not belittling the Zeiss lens by any means - it is a great lens as are all the Zeiss lenses I have ever used, but comparing the R1 (a high-end P&S) to a true interchangeable-lens rangefinder is comparing apples to oranges...Zeiss and Sony conspired to produce the R1 a full year before the M8. The R1 had the back lens element about 1.5mm from the sensor. Go read reviews about how well it worked.![]()
Yes...micro-lenses do both things. One is why they were added and the other is an unavoidable consequence.The purpose of the offset microlenses is not to constrain the acceptance angle, but to redirect the diverging light rays down into the photosite wells, but I think we are saying the same thing here...In addition to the above, adding a micro-lens array above the photosites further constrains the acceptance angle. Even if the micro-lenses are offset at the edges, the acceptance angle is the same...just pointed in a different direction.
I wasn't comparing them, just showing that it's possible to make a good lens that sits very close to the sensor w/o optical problems.It Leica and Kodak's breakthrough in sensor design that enabled acceptable response to those light rays, and what made it happen for digital rangefinder cameras having interchangeable lenses and sensors large enough for pro shooters.
