That's what I did. The filter itself provides a slight bit of extra protection against glare, which seems to be increased a little more by using a step-up ring (where there is also zero chance of vignetting, so there is a tradeoff that's not entirely negative).Very nice.
I'm thinking about buying a single 77mm filter with stepping rings. That way I don't need to buy a filter for each of my lenses. I guess the only disadvantage is some lens hoods might not fit.
--Does anyone have any examples of using a circular polarizer on snow, in particular landscape shots? I'd be interested to see the effects as I do not currently own a CP.
Here are a with and without for you from Sunny and Snowy Ohio today. First shot with , second without. I have a Kaesemann MRC Circular Polarizer. Taken with my 17-55.Thanks for the advice. I'll probably purchase one eventually, I just wanted to see if there were any clear advantages to using one in snowy conditions.
or ... buy good quality brass rings and not have to worry about them sticking together or bending / warping. They also are more compatible with high quality fillters that have brass construction. If you are going to pay $$$ for a high end filter, do yourself a favor and get brass stepping rings.I don't like step up or down rinds .
BUT if you are going to use them , buy at list 2 of each size [ they can bend and warp ] buy all at same time - .
--Very nice.
