What I meant by 'blur' was that in one photo the edges of leaves
are sharp lines and in the other the are soft --if I enlarge twice
on the LCD.
In the middle distance photos, I had a cupboard with a plate
showing pigs. In one case the drawn outline of the pig showed, in
the other it was blended or blurred into the pig's color.
Thanks for your thoughts on sharpening. I figured that action would
affect the whole scene and not just the central plate.
I erased the original tests but will take some more to post.
Carter
Sharpening
Thank you both for replying. I did go out and try to duplicate this
problem with a more distant subject. The blur happened again on the
same settings in TV but again Auto was sharp and crisp.
The funny part is that my photos are always in focus in P mode and
I only started to test TV and M mode because other good
photographers seem to be using them in clever ways.
Carter
Michael
How are you judging this sharpness, on the LCD? If so then are you
by any chance using RAW in Tv and M but JPEG in Auto? If you shoot
raw the LCD display of the image is from a tiny, highly compressed
thumbnail.
http://edsphotos.us/
http://www.pbase.com/mooremwm
http://www.photosig.com/userphotos.php?id=7178
