has anyone got the same NEF problem
ascorth
Member
Jakarta Selatan (Kota), ID
i got this when edit NEF...
so far it ruin 2 photo.... and too bad... the most i like it...
anyone has the same problem...
or anyone have a clue what causing this error...
thanks for reply... i really appriciate...
Ridwan
It looks like a codec problem to me. If it is Adobe you are using, you can download a plugin on the Adobe site. They will explain to you how to install it.
groetjes
L-A
replace SD card, it may be faulty. Had it on my D80, formatting fixes the problem but comes back when you least expect it. I as well had that with failing HDD and only NEFs would look like that. It has something to do with checksum/integrity of data pack. If you look closely, you may find even JPEGs sort of "scrambled", sometimes offset between lines may be just a pixel, sometimes more. On my card, it would happen when it was 75% full (so must me failed memory around that allocation unit).
cheers
im sorry i didnt tell u ..
im using viewNX.... and the file are from D90
thanks alot...
so the problem from the memory card.....
fiuhh.... glad its not becos the camera....
