mark_ken9820
Active member
The Traveller8 is marketed as a more portable replacement for umbrellas. It's definitely an improvement over using an omni-bounce. I'm not sure if this is a particular issue with the AF540, but the flash head's vertical angle adjustment isn't tight enough to hold the traveller8 at intermediate angles. That's not an issues as I have the flash mounted to a camera tripod with a ball head, but if you were using a light stand with a fixed head , it might be a problem.
