LX93
What are the pros & cons of each?
Muslin is a lot easier to transport.What are the pros & cons of each?
I probably should've mentioned that I'll be working on-location pretty much exclusively. Does that completely rule out paper for my situation? Doesn't muslin also get wrinkled when transported?
lbdina wrote:
paper doesn't wrinkle... What you give up is portability.
Lou, thanks for the warning. If I remember correctly, the one I used (borrowed from a friend) was a 5x6 and I had no problem having it stand against a wall without any sag. But as I plan to buy a larger one, I'll be careful about this issue.I agree with Eric, but be sure to get a decent brand. Some of them are flimsy when opened and don't stay open without support. I have a 6x7 foot collapsible by Superior, and I consider it to be "inferior". Damn thing flops around and needs as much support as seamless! If you go that route, fine a brand to opens flat and stays flat without a lot os extra support.
This will give you an idea of the color:
http://www.backdropsource.com/Productinfo.asp?id=1198&pname=thunder-gray-background-paper
http://www.blackcanyonsystems.com
Lawrence
