Scott Pickering
Leading Member
I see on Ebay some inexpensive Canon grips for the 1000D and T2i for $30 from a Canadian seller. Is there anything wrong with these other then they are not official Canon pieces?
You didn't insert your battery correctly. AFAIK, all grip are wired in Parallel in order to maintain 7.2 voltage requirement. Parallel wiring allow you to use just ONE battery. My grip works beautifully with just 1 battery.Does it need both batteries in it to turn on the camera? I tried it with 1 I have and it wouldn't turn on. I do have a second battery coming, but I wanted to start using it now. Any comments? Maybe the batteries are wired in series in order to work?
