I used the D90 and XSi as those were the cameras mentioned by the OP. I have no idea what the average inaccuracy is across the market, but it doesn't matter, the fact that differences exist means that it's hard to make direct comparisons between models.
If it interests you that much, and makes that big of a difference, it's quite easy actually. Just compare the two models. My point is that there is a standard in place, and generally speaking it gives you a pretty good idea of what your ISO sensitivity is. And if you are going to forgo the purchase of a certain camera because it has ISO200 as a base ISO, especially considering there are ND filters available for use, you are being a bit silly. Even if there is a slight variance in the ISO ratings.
Well from the graph you can see that the true sensitivity is around 150.
If you want to be really accurate, I think it is closer to 160-170, but whose counting?
