F
Furrukh Khan
Guest
Dear Friends, if you are in the market for a tripod, then you may be interested in the Bembo Trekker. I have known about this tripod for some years, so when I saw it at our local camera store I could not resist buying it. I am sure that this tripod has been discussed in this forum, so please excuse any repetitions. The tripod is a very different design compared with a “normal” tripod. It has a boom like column, to which you attach the camera via. a ball head. This arm can be positioned at any angle, making this tripod very flexible for still life, macro, and all sorts of photography. This “arm” can be brought all the way down close to the ground at any angle, and also moved in an arc, all the way to the top. The three legs can be adjusted individually for flexibility. The Trekker model is for outside use, and weighs only 5 pounds. It is designed so that it can be used in a few feet of water, and even mud. Bembo Trekker is made in England, and costs $255 at B&H. You can see its photograph at B&H:
http://www01.bhphotovideo.com/default.sph/FrameWork.class?FNC=StartLink__Aindex_html
Just go to Photo-> Photo accessories-> Tripod & Camerras -> 35mm/APS tripods-> B1007 Trekker Tripod Kit.
A few years ago there had been some concerns about slippage in these tripods. Apparently this problem has been fixed. I tried all my force to make anything slip, but it remained solid. It comes with a light weight (Bogen mini) ball head, which should be more than enough for the Cool Pix cameras. Other ball heads can be attached for heavier 35 mm cameras.
I am going on a long trip in a few days, and will put this tripod through its paces during this trip. When I come back I will post a mini review. I will look out for any slippage, etc. Meanwhile here is the first outside photograph I took using this tripod:
http://www.dpreview.com/forums/read.asp?forum=1005&message=377788
Cheers!
Furrukh
Cheers!
Furrukh
