Read the the posts here in this forum, particularly from years back when the S2 Pro was new.
Generally though, here's some tips:
Jpeg shooting: Org Color, Org Tone, Std or Hard sharpening.
Turn the LCD brightness all the way down; the default setting is too bright.
Disable closest focusing priority (use the CSM setting on the top left dial, then select the focus settings)
The center focusing sensor is the most sensitive one.
Flash metering: spot metering gives you true TTL, but the spot has to be on a neutral color (not black and not white) to get accurate exposure.
Compact flash cards--superfast ones don't work any faster in camera, but using a good external card reader will take advantage of any speed in the card. It's worthless to use the camera as a card reader.
Always use CR123 batteries if you want reliable power (the S2 Pro uses both AA and CR123). Without them, the AAs get too much drain on them, causing erratic behavior in some instances.
good place to get CR123A:
http://www.botac.com
Not sure if the Series E lens will fit/work or I don't think you'll get metering with the AI lens.
Anthony
I just picked up a Fuji S2Pro locally and was wondering if anyone had any advice about how to get the most from this camera. I normally shoot Canon, but wanted to try a Nikon mount body and I've always heard good things about the Fuji sensors.
The lenses that I'm using are the ZF25/2.8, CV Ultron 40/2, Nikon 18-55VR, Nikon 50/2 AI, and Nikon E 75-150.
Thanks in advance.
Cal
check out my blog at
http://anthonyonphotography.blogspot.com
