If you work in layers, flatten a
copy of the image.
Working on the copy, do your typical sharpening on the full size image. There are all sorts of ideas about what is best here, and different images might require different settings. If you started with RAW images (hence not sharpened in the camera), one generic approach that can be a starting point would include:
USM at amount:12 and radius: 50
Smartsharpen at amount: 300 and radius: .3
Yes, both of them. (I typically do this
before flattening, but my workflow is probably different than yours. Among other things, my primary target output is print not web.)
Resize using whatever method your normal software provides. What you are most concerned about here will be the pixel dimensions - resolution isn't really relevant here.
At this point you may want to do a bit more USM sharpening to "compensate" for detail necessarily lost during the resizing operation.
Once you get a workflow that you like, you might turn the whole thing into one or a series of actions so that you don't have to repeat all of the manual steps every time.
Dan
I shoot with the 7D and 15-85 IS, 100 macro 2.8 L and 100-400 L. I want to know which is the best way to resize for posting on the DPR forums so I can retain good sharpness & detail. I use DPP and PSE/PS5.
Thanks in advance.
Cheers
Dr. Sanjeev Aurangabadkar MD
Hyderabad, India
G Dan Mitchell - SF Bay Area, California, USA
Blog & Gallery:
http://www.gdanmitchell.com/
Facebook:
http://www.facebook.com/gdanmitchellphotography
Flickr:
http://www.flickr.com/photos/gdanmitchell/
Twitter:
http://twitter.com/gdanmitchell
IM: gdanmitchell
Gear List: Cup, spoon, chewing gum, old shoe laces, spare change, eyeballs, bag of nuts.
