Jim Cassatt
There are times when you want to pose a model against a window backlit by sunight, perhaps with a sheer curtain in front. I have also seen interesting pictures where the window is on the side and the light is coming through venetian blinds.
My problem is that my studio is in my windowless unfinished basement. In addition my wife tolerates my photography as long as models are confined to the basement and are not allowed to invade our living space
So my idea is to construct a frame for a double window and hang it from the rafters. I keep a roll of white seamless paper up semi permanently since the stuff is such a pain to roll and unroll (and hang other backcrops in front of it). For the backlit pictures, I would just use reflected light off the backdrop, just as I do for high key portraits. I could also move the window off to the side and light it through a large diffusion panel.
I was thinking of constructing the thing out of 2x4's, but decided against it because of the weight. So I think I will use 1x4's and trim it with 1x2's. This arrangement is inherently unstable, especially if you just nail it together, so I think I will use mortisse and tenon joinery for added stability (it helps to have a well-equipped woodworking shop although I don't have a dove-tail jig).
I guess my questions are, has anyone ever done something like this; am I missing something and am I doing a lot of work for nothing when there may be some sort of commercial product available?
Jim
http://www.pbase.com/jcassatt
Jim
