I posted this in response to a thread, but I thought it might be useful for a wider audience, so...
PC monitor settings are often all over the map.
The following chart can help you know if your PC monitor is set so that the gamma response is more or less proper (at gamma 2.2). It's copied from an old web site that's no longer around. Bravo and thank you to Timo Autiocari, who originally created it.
The dark vertical bars along the right contain alternating black and dark gray squares. If you can (barely) see the differences in the dark squares in the upper one and can't really see them in the lower one, then you're pretty much right on. Also, your overall gamma should be set so as to make the larger vertical bars both look like smooth gray gradients, light to dark, with no color or differences side to side. In practice it's hard to get them perfect, but it's possible to get them very close.
-Noel
Member said:NOTE: Make sure you're viewing this chart at 100% zoom or it falls apart. |
-Noel
