Having both cameras, I find myself carrying the sony 70% of the time.
It's has a faster af, and the ziess is pure swag.
I carry the canon to club gatherings due to the fact that everyone has one, just wish canon had a separate class of lens to separate from the red ring. Bragging is not the same when everyone has a red ring.
Zeiss lens are overrated and expensive. The ones they made for Canon arent much better and sometimes not as good as Canon L lens.
I can see that you have very little direct experience using Zeiss lenses on a Canon DSLR - because if you had, I don't think that you would be so disparaging of the Zeiss as compared to Canon's offering.
Yes, Zeiss is somewhat more expensive than their Canon equivalent lens counterparts. The Zeiss 50mm 1.4 ZE is the new 50mm normal lens standard for FF, 35mm DSLR's in overall performance - especially wide open - with the best bokeh I have seen thus far from any modern 50mm prime.
And in the wide angle end of things - the Zeiss easily trounces ALL of Canon's offerings in the prime and zoom range as well (below 35mm's).
The Zeiss 21mm f2.8 ZE (as well as it's legendary predecessor: the 21mm Contax f2.8)
stomps all over Canon's 24mm f1.4 II wide open, and also in CA and distortion. Same is true for Canon's very weak 20mm f2.8. The only prime lenses where Canon does have the definitive quality edge over the Zeiss is with their outstanding 35mm f1.4, and the 85mm f1.2 - which are the sharpest and best performing lenses that Canon currently makes under 100mm's.
The Zeiss MF lenses are not for everyone, or for every type of photography, but the new their ZE line-up is a very good option indeed on any Canon - especially on a FF DSLR. I happen to be lucky enough to own the Zeiss 21mm f2.8 in a C?Y mount with an EOS adapter. As primarily a landscape photographer, I have never been so impressed with a lens as I am with this gem. It's a 10+ year old 35mm film lens that can still deliver class leading wide-angle performance on a modern 21MP FF DSLR.
That's how good Zeiss lenses are and have always been - built to last - performing at the highest optical standards from decades past, and many more decades to come.
