Slowest memory card on the market can do 5 fps for a short time as the buffer can hold 15 or so frames in RAW. After the buffer fills up, the memory card write speed matters a great deal. I think the K-7 can push about 20 MB/s to the memory card, maybe even more than that. So the Ultra II will limit the K-7, but it shouldn't be bad. My guess is it is your AF setting as well.Sandisk Ultra II is too slow. It is a card good enough for the *ist-serie, but the K serie is faster and K-7 can clearly take advantage of faster cards.
AF-S waits for focus only on the first shot, and on shots after that AF is disabled.Doesn't AFC fire whether you are in focus or not? AFS waits for focus.
The card has nothing to do with it. At least not before the internal camera buffer is full.Anywho, after I got that all my burst problems disappeared too. I sometimes use the autobracket burst mode for HDRs when I'm too lazy for a tripod and generally the busy light has already stopped flashing by the time I look down at the camera again. Got to test it again the other night, doing a giant series of 6 to 14MP JPGs to string together into video clips for 2 live bands. Shot 580 pictures in 5fps burst for about 2 hours straight and never had a slowdown... so yeah, it's definitely the card.
Maybe it's just because the K-7 can't really achieve 5fps in continuous AF while tracking a subject? The focus track algorithm/mechanism is still not fast enough for that and you won't get much better performances from a faster card or a faster lens.Hi all. How come that when I got continuous shooting om hi the k7 doenst make 5 fps? Suggestions?
