I'm interested in dpreview users' opinions as to why 85mm lenses are so popular for shooting portraits. I can confirm that I find that 85mm produces good results for head and shoulder shots, but I'd like to know why. Can you help?
Let's assume we're talking full frame here, so we're discussing a conventional 85mm lens on a 35mm full frame body (film or digital).
I'd be grateful if you could reply stating which of the following explanations you agree with:
A) Everyone knows that 85mm is best for portraiture. There's no need to ask why, it's just a given. That's why it's included in every photography manual.
B) 85mm lenses produce the most flattering linear perspective. They compress noses, thus making subjects look good. Wider angle lenses do not compress noses as much, so there must be something in the optical configuration of glass elements in an 85mm lens that distorts peoples' faces in a good way, to make them look more flattering.
C) 85mm lenses are popular for portraits because, in order to fit a subject's head and shoulder in the frame, you have to walk back several feet from the subject. When positioned several feet from a subject the perspective is much more flattering than if you are positioned very close to them. It's not the focal length of the lens that makes the photo flattering, but the fact that you have to position yourself several feet away.
D) None of these is correct. The real explanation is .....
