Just like in a laptop computer you can replace the graphics card. They should make digital dSLR cameras modular so that you can have a collection of lenses and sensors.
If that was the way that dSLRs were, you’d see a variety of specialized sensors, and you could use them just like different types of film.
But we’ll never see that because Canon wants to sell you a compete camera body with every new sensor.
Last time I checked, you can't replace the graphics card in your laptop, its embedded in the main board, but maybe you can on your desktop.
Seriously, though. To make a body that would allow changing the sensor & support electronics would be much more expensive than a high end DSLR that is integrated. It would also be bulkier & present more sealing & alignment problems.
The interconnections are another issue. With it all integrated, the signal paths are short an there effects on the highbandwidth signals are well controlled. Now you have to support those data rates across a flex circuit & connector?
Then of course there is the reliability issue with interconnects. You do realize one of the most unreliable parts in most electronic designs is the interconnects. Cables, pins, sockets.
Then what about AF, you want that modular too?
There is no practicality or economic reason to pursue such a design & product.
So that would have to always make this sensor package backwards compatible withe some "mother body". Like that technology would never change. How about the the Digic or other named ASIC that would constantly be evolving for higher Mp sensors, faster DMA rates, higher resolution A/D converters etc.
The Rico design, while novel & niche, won't make much of an impact I predict will not last.
'A bad idea in search of a good cause is..
just a bad idea' ... me
