tivoboy
Just a warning, but a NEW 2.8 IS v II is already out, pricing is yet to be determined.
No doubt both are very good lenses. Both have likely produced many images we have seen in newspapers or magazines yet nobody says "oh, that is so much sharper it must have been taken with XXX lense".I owned the 2.8 IS and then bought the 4 IS with return privleges to compare them to each other. In my comparisons the 4 IS was clearly superior optically in terms of sharpness, color, and contrast. The 2.8 IS is very good by all accounts, but the 4 IS is one of the optically best lenses that Canon has ever produced and some reivews have said it provides the quality of primes throughout its range. It has a glowing reputation like the 135 f/2L and the 100mm f2.8L IS Macro do.
That really is a personal preference. The f4 sounds like the right choice for you although the comment regarding "well-hung" seems to indicate that those who need or want the 2.8 are deficient in some personal attributes which I think is a little unwarranted. If the f4 is what makes you happy fine, if the f2.8 makes others happy, good for them - no point making personal slights.The 4 IS is much more managable to carry, hold up to your eye and to work with because it is much lighter and smaller than the 2.8. The size of the 2.8 will make you feel well-hung, but it gets in its own way for me.
So following that logic, the IS on the f4 version provides no IS benefit over the 2.8 IS version as far as IS is concerned (reported 4 stop IS on f4 but half the light coming through compared to reported 3 stop IS on the 2.8 with twice light coming through). But if IS isn't really usuable for a situation, then the 2.8 lense could make the difference between getting the shot or not.Finally, the 4 IS has four stops of IS; the older (and about to be replaced) 2.8 IS has three. For me, at tele distances and with what I shoot, waiting for a pause in subject movement and hand-holding with four stops of IS works extremely well. I sold my 2.8 IS and bought the 4 IS and a 1.4 Canon TC for the same money.
There really isn't a right or wrong answer here. Both lenses are good, both are capable of producing very sharp images, both have pro's and cons (f4 weighs less vs 2.8 af sensitiviy for example). Personally, I like the added weight of the 2.8 IS. I have hiked with it all day and enjoyed it (sure I was tired but was that due to the hike or should i blame the lense?). In the end it doesn't matter what I like. What is important for every poster is to provide objective feedback regarding the lenses and the OP to go to a store and try them out - or better rent both and see if one fits them better than the other. Just because the f2.8 is to much for you doesn't mean it will be for the OP.--
Peter
--I was faced with the same question. I chose the 4IS.
1. It wasn't for the money, it was for the weight. The 2.8 is almost 800 grams more, that's a pound and half. It may not sound like much, but I have some right elbow injury and when I have to lift the 3 kilos or 7 pounds for 6 to 8 hours... camera + lens + flash
2. The optical quality of the 4IS is fantastic, the 2.8 is "only" excellent.
3. Most of my shooting is done at f/5.6+
4. I don't do too much dark, dark focusing where I would need the f/2.8 to focus.
http://foto-biz.com
The Business of Being a Photographer -- Lightroom Q&A
Actually, on the autofocus issue, when I was comparing the two lenses I found the f/4 IS to be quicker and more reliable than the f/2.8 IS on very low contrast, dimly lit targets. One of my most difficult targets was a white wall plate for a light switch on a white wall. I just recreated the situation, and the exposure was 1/4 sec at 3200 ISO at f/4, with the f/4 IS quickly locking focus on the lightly shadowed edge (where there was a bit of contrast). I think it does so well against the f/2.8 in this situation because it has better contrast and sharpness at the maximum aperture that is being used for focusing. The 2.8 IS lacks contrast and has reduced sharpness at maximum aperture. This would hurt its focusing relative to the contrastier and sharper f/4. This was my comparison. YMMV.There really isn't a right or wrong answer here. Both lenses are good, both are capable of producing very sharp images, both have pro's and cons (f4 weighs less vs 2.8 af sensitiviy for example). Personally, I like the added weight of the 2.8 IS. I have hiked with it all day and enjoyed it (sure I was tired but was that due to the hike or should i blame the lense?). In the end it doesn't matter what I like. What is important for every poster is to provide objective feedback regarding the lenses and the OP to go to a store and try them out - or better rent both and see if one fits them better than the other. Just because the f2.8 is to much for you doesn't mean it will be for the OP.
Don't take this the wrong way but you couldn't have possibly tested/compared the AF speed if you only own the f4 (you indicated you "owned" the 2.8 but returned it. So your result is based on a memory of a lense you owned for a short enough period of time where you could return it (say 2 weeks, maybe 30 days??). You also have to consider the body you had it on since the body actually does the AF - the lense is just a piece of the equation. The f4 I tried was quick focusing, as quick as many USM lenses I have used including the 70-200 2.8. If there was a difference in the speed where focus was obtained, I didn't even notice it.Actually, on the autofocus issue, when I was comparing the two lenses I found the f/4 IS to be quicker and more reliable than the f/2.8 IS on very low contrast, dimly lit targets. One of my most difficult targets was a white wall plate for a light switch on a white wall. I just recreated the situation, and the exposure was 1/4 sec at 3200 ISO at f/4, with the f/4 IS quickly locking focus on the lightly shadowed edge (where there was a bit of contrast). I think it does so well against the f/2.8 in this situation because it has better contrast and sharpness at the maximum aperture that is being used for focusing. The 2.8 IS lacks contrast and has reduced sharpness at maximum aperture. This would hurt its focusing relative to the contrastier and sharper f/4. This was my comparison. YMMV.There really isn't a right or wrong answer here. Both lenses are good, both are capable of producing very sharp images, both have pro's and cons (f4 weighs less vs 2.8 af sensitiviy for example). Personally, I like the added weight of the 2.8 IS. I have hiked with it all day and enjoyed it (sure I was tired but was that due to the hike or should i blame the lense?). In the end it doesn't matter what I like. What is important for every poster is to provide objective feedback regarding the lenses and the OP to go to a store and try them out - or better rent both and see if one fits them better than the other. Just because the f2.8 is to much for you doesn't mean it will be for the OP.
Peter
Fantastic vs Exellent is my personal opinion of the optical quality of the lens. Before buying the 4IS, I tried both and decided mostly because of the weight and size.So, "fantastic" is better than "excellent"? Is that true in low light with moving target too?
I am in the same situation trying to decide between these two lenses.
My quality criteria is for the best sharpness and contrast.
Looking at test charts it seems like the F/4 is the superior both in optical quality and contrast.
First when you stop down the F/2.8 to F/5.6 it starts to equal the F/4 in sharpness but still lacking in contrast.
When it comes to the "lowlight capabilities" of the F/2.8; isn't this a quality that is slowly getting outdated with the increasing higher ISO quality of newer cameras?
Except for the "shallow DOF" quality of F/2.8.
But for "shallow DOF portraits" situations I can get a 135mm F/2.0 L together with the 70-200mm F/4 IS for about the same price as one 70-200mm F/2.8.
Check out the comparison test charts (mouse over) and adjust the focal lengths and F/stop to see the quality difference. Notice the contrast differences even stopped down.
http://www.the-digital-picture.com/Reviews/ISO-12233-Sample-Crops.aspx?Lens=404&Camera=453&Sample=0&FLI=4&API=0&LensComp=103&CameraComp=453&SampleComp=0&FLIComp=4&APIComp=0
--is the f2.8 worth the extra $800.?
thanks
Yes, this is exactly what I found when I compared the two lenses over three weeks.I am in the same situation trying to decide between these two lenses.
