1DMk1V: My Wildlife perspective
NRich
Vancouver, British Columbia, CA
Greetings from Vancouver.
I am writing to share my wildlife perspective on the newly released 1DMk1V, that I own and am actively shooting with. I have a 1DMkIIN for back up. My1DsmkIII is used primarily for landscape. The 1Dmk1V in my field use is becoming a very satisfying 1D series body.
The decreased noise in combination with the increased mega pixels from 8 in the 1DmkIIN, to 16 mega pixels in the 1DMkIV is of significant benefit to me. These 1DMk1V advancements in retention of fine detail with smooth and tonal gradients, allows me to shoot at higher iso and/or smaller apertures, The new low noise capabilities of the 1DmkIV in early evening or late afternoon light has IMO a capacity to open up new worlds of possibilities for wildlife photography.
I approach photography as an artists medium, with the intent of creating fine images that honor wild nature. The equipment, at whatever stage of evolution, is for me a means to that end. I shoot in raw format, frequently with tele-converters. At distances closer than 60' I often close down the lens to f/5.6 to f/11 increasing DOF.
My focusing orientation is to select and place one of the 45 AF points on the eye of the wild life subject. I usually shoot in short bursts of 3-5 shots that are specifically timed, from a stable shooting platform, using a Wimberley on heavy duty Gitzo G1548 legs, and in return I am pleased to be receiving better than 85% + tack sharp files, in a variety of field conditions.
Image quality is key to me, as my final output is prints on canvas to 36”, on the long side for gallery exhibitions. I find the 1DmkIV files, with care and attention to qualities of light and exposure are IMO loaded with nuanced detail, and subtle tonal gradation. I am receiving a high proportion of tack sharp images with the Canon 2x tele-converter, as well as the 1.4 tele-converter.
In my experience each camera sensor has an intangible aesthetic character or signature. In this regard I am pleased with the 1DMk1V. To date the 1Dmk1V raw files from fine optic glass such as the 500 f/4 are a pleasure to work with as they are responding well to editing choices. This may in part be a benefit from what appears to be a lower anti-aliasing filter.
My intent is to work to a camera's strengths. I believe one must put in their dues to get the most out of any given camera body. There are many ways of making balance with equipment and shooting styles, and IMO the attitudes one brings to their chosen equipment influences the possibilities. I look to myself to elevate the creative process, and look to the hardware to be responsive to my visual choices, and not get in the way of the inspiration. From this perspective the 1Dmk4 is proving increasingly satisfying for me to work with.
Your thoughts?
Norman
Additional samples along with exif information are here: http://www.pbase.com/norman/1dmk1v_
Below: 1DMk1V exposure and detail across a wide range of exposure values. Bird photographers know the challenges to retain a high level of detail in both the black feathers as well as a good exposure and detail in the white bill when photographing the American Coot. 2x tele-converter on 500-mm lens (1000.0 mm) @ 1250 iso.
Below: Capturing a moment with 1DMk1V color and tonalities, photographed with Canon 500-mm lens @ 640 iso.
Below: Great blue heron at dusk: 1DMk1V-2x tele-converter attached to the Canon 500-mm lens - 1250 iso
Pleased to hear that you are satisfied with the performance.
As a point of interest what c fn III settings do you find suit your bird photography. This particularly applies to birds in flight.
My experience pretty much mirror yours. One of the most surprising things I have found since purchasing the Mark 4 is that my 500 f/4 is sharper than I had ever imagined. The level of feather detail I am seeing is incredible to behold.
I haven't quite gotten my workflow down in post yet and feel much more at ease editing the Mark 3 files. However, I am sure that with time I will find a work flow that appeals to me.
Enjoy your new tool, I'm sure it will serve you will.
Ken
Canon 1D Mark 1V, 1D Mark III, 1D Mark IIn, EF 17-40L, EF 100mm f/2, 100-400L IS, 400 5.6L, 500 f/4 L IS
http://ken.smugmug.com/
Hi Brian,
I often use a two camera body system in the field. One body is on the tripod, the other on a strap over my shoulder. One body usually is set to a single selectable point, the other set to point and surrounding points. I far prefer selecting a single point focus in most shooting circumstances, and find I rarely shoot with all 45 points in play all at once. Most often the animal or birds eye is the precise point of focus, and an aperture/ DOF is chosen according to the distance being shot and the size or body depth of the bird, or animal.
The two bodies are usually set up a little different according to the field circumstances that I am anticipating. This may vary greatly from caribou in open arctic tundra, to the low light and thick branches surrounding eagles in deep forests of S.W. B.C. I am currently awaiting an order for a 90 mb/s UDMA6 flash card. With this card I will set aside a day or so specifically for BIF with the 1DMk1V.
Norman
Hi Ken,
Yes, This is what I am finding as well. The feather detail as a reference with the 1DMk1V is simply stunning! The 1DMk1V is pulling considerably more out of the 500 f/4 that I had previously experienced. This is giving me not only a certain regard for the 1DMk1V, but also a new respect for the 500 f/4, and what it is capable of in combination. Each new day I shoot I am eager to get back and review the days files. The difference between the fine feather detail in the 1DmkII and the 1DMk1V is IMO huge. And I do consider the 1DMkII a fine body (for which I have fond memories,) having recently sold it after some 70,000 wildlife photographs.
Norman
Recent 1DMk1V crow portrait below:
Hi Norman,
Many thanks for the response. I have only recently acquired the 1D MKIV and owing to the dull weather here in the UK the bird photography has been somewhat restricted.
However, I was able to test it on Thursday with a 300mm f2.8 plus extender 2.0 with limited success. I need to adjust some of the c fn settings and hopefully the results will show a marked improvement. Patience is a virtue.
Brian.
It would be nice to see some samples of your work with the 1D4.
Mike S
What a pleasure it was to read your review Norman and even better with the great pictures you posted. My 1D 1V arrives Monday and I have the 600mm so am really interested in trying it out. I shoot mainly wildlife and birds in flight. For still shots I use the 600 but for bird in flight I prefer the 400, 5.6 and my 100-400.
regards
Allan
http://www.flickr.com/photos/ashcroft8/
Hi Norman,
Enjoyed viewing your 1D MKIV samples particularly those on high ISO settings. This confirms my decision to purchase this camera.
Brian.
Hi Brian,
The 300 f2.8 is IMO a magnificent lens, very fast and very sharp. However when a 2x tele-converter is attached, I find the combination becomes significantly slower to lock on and sustain focus with moving BIF. It may be less a matter of settings and more an issue of inherent limitations using a 2x tele-converter with birds in flight. For this reason I have chosen not to use a 2x tele with BIF, as inconsistent results IMO are neither the fault of the lens or the camera body.
My suggestion would be to consider the relatively light and affordable 400 f/5.6: (for me a pleasure for BIF) It is very sharp wide open, and still workable, though slower with a 1.4 tele-converfter. Ideally I'd recommend renting a 500 f/4 ( to see if you might want to head in this direction with a longer lens in the future). The 500 f/4 produces stunning results with the 1DMk1V. and having shot the 1.4 teleconverter with 1DMkII, (see eagle photo below shot at 700mm) I have strong expectations of getting excellent BIF results with a Mk1V with both the 500mm bare lens, and a 500mm with 1.4 tele-converter combination.
Norman
Hi Norman,
Brian.
Hi Mike
As you mentioned the high iso shots , I'll include a few of the high iso Blue heron shots here for others.
This was a particular patient heron:-) These were all shot with the bare 500mm lens (very sturdy tripod set-up, shot kneeling, the tripod legs shortened for additional stability). I had a real reluctance to put the iso up to 2000, (un thinkable but a few years ago)..let alone to 3200, then 6400 iso... and I was very pleasantly surprised.
Results below:
additional exif here: http://www.pbase.com/norman/1dmk1v_
Below: 2000 iso-
Below:3200 iso-
Below: 6400 iso
Hi Norman,
Brian.
Excellent results for the lighting you were shooting in.
Here's one from last weekend with the 500 f/4 in better light. The details at full resolution are stunning. The tip of the beak is OOF because it was so close and the narrow DOF at that range. 50% crop for composition.
ISO 400, f/5.6, 1/3200 handheld:
Ken
Hi Alan,
I can feel your enthusiasm.Thank you for including your fine heron shot in warm light, and gorgeous color. Long beaks at relatively close distances can mean increasing DOF, and increasing iso. We collectively make take some getting used to the new opportunities in higher iso settings of the 1DMk1V. Previously my default setting in many bird and wildlife contexts was 320 iso. I am considering raising that bar to a default setting of 640 iso.
I can imagine it could be encouraging to you with your 600 f/4 that I am getting consistently good results with the 2x with birds on land, shot from a stable tripod. I too would be inclined to use my 400 f5.6 with handheld BIF with the 1DMk1V, though I admit I am curious to see how it performs with the 500 f/4 when the new 90mb/s -UDMA6 card arrives.
Norman
Below: gull portrait below shot at 640 iso
regards
Allan
Great write up, and great images. One thing I have noticed with 1d-mk4 bird images so far is some lack of contrast or perhaps processed a bit bright? This could just as well be a monitor profile issue.
The feather detail on the included images are fantastic, and nothing is blown, but the overall tone is what I am speaking of and is almost certainly a post processing thing.
I have no intention to get a 1d-mk4 and probably should stay out of this conversation, but I offer this comment as a single input that could be way off base but with a 5% chance of having some merit.
I know what I would do is darken the mid range.
When you can't focus, nothing else matters
Once you can, everything else does.
http://ben-egbert.smugmug.com/
Ben
Hi Ben,
Please select a few 1DMk1V images in the thread regarding contrast and brightness. I will follow up from there.
Norman
Thanks for taking this the way intended. In all of the images in your sample post, I think I would prefer blacker blacks. Don't get me wrong, I would die to have such great images, but this is my subjective take regarding post processing only.
The first image would be a good one to use as a test of my idea. It would be interesting to hear if others agreed or not. I am never sure about this sort of call on a medium where no two monitors are calibrated at the same brightness level, or where we use different browsers. I use Safari, which is ICC aware. I cal at 110 CD/MM^2 if that matters.
If I were printing, I might keep the lighter image as my printer tends to darken anyway.
Ben
Hi Ben,
In a purely technical sense I would agree with you regarding a black levels slider setting adjustment. As you know editing choices may differ depending on the intent and output. In these samples I have as you noticed backed off the blacks a bit. My intent: to open up the darkest (near black) tones for the purpose of revealing detail usually lost in deep black feathers. A credit to the 1DMk1V there is IMO considerable detailed tones in the white coot bill, that is also retained. In print output I would be inclined to further adjust (deepen) the blacks, adding an S curve adjustment before sharpening.
In my first field work outings with the 1DMk1V, I find myself putting special attention on dark birds such as crows and coots, and also white birds such gulls. I am enjoying exploring new limits of lower noise in combination with higher resolution in the 1DMk1V. I think it may be of value to note this Coot close up was shot at sundown with a 2x tele-converter on 500-mm lens (1000.0 mm) @ 1250 iso. A credit IMO to the capabilities of the 1DMk1V and 500 in combination.
In artistic terms holding highlights, while retain lowing noise and detail in the dark areas, and shadows is of special importance to me in wildlife photography. For example mature Bald Eagles with dark body feathers and white head feathers pose just such a challenge, and I have spent considerable time in this pursuit with a number of Canon bodies: http://www.pbase.com/norman/nature_of_eagles In viewing the 1DMk1V from this context, from my experience, for my purposes, it is rapidly become a joy to use.
In the sundown crow portrait below, again in pure technical terms I agree that a small adjustment to the level sliders would produce richer blacks. At the same time, there are trade-offs in posting for the web, as my intent here is to see further into tonal details. These subtle tonalities and fine feather detail in the mid-tones and blacks, at dusk with a 1.4 teleconverter @ 1250 iso delight me, as I hope it would other viewers.
Norman
