transferring photos directly from camera to external hard drive
michelephoto
Member
US
How do you transfer photos directly from camera to external hard drive? I have an Iomega external hard drive and am happy with it so far. Will probably need to get another external- so am open to suggestions. I have Canon EOS 7d.
thanks!
I looked up that device- $1,500. too pricey!!!! anything for less than $100.
Nope. A normal external hard drive needs something in between to communicate; i.e. something with an operating system. What you should look for instead is a Portable Storage Device. Ask your question on the Storage & Media forum. Not quite the same thing, as it requires removing the card and inserting it into the PSD for copying, but far cheaper than the wireless transmitter and not quite as expensive as a laptop (though close in price to a netbook).
Mark
There is a device that I was considering at
http://www dot usbgo.com/
Features:
U2 Bridge with 2 built-in USB OTG ports to connect Two USB devices
Any USB device, compliant with USB mass storage protocol, like Card Reader, Pen Drive, External Hard Drive, Voice Recorder, MP3 Player, Digital Camera, PDA, Image Tank, X's Drive........ are compatible
Non PC to work- PC Free Application
Copy date from Source port to Target port
Mini Size- Easy to carry and to go everywhere
Simply one touch button to share data with your friends, and provide service between 2 USB device anytime and anywhere you want
powered by 3 AAA batteries
MichaelV
Where are you shopping? The WFT-E5A is around $700 at B&H in New York.
For less than $100, buy a large CF card and be happy. What are you trying to do with a hard drive output, anyway? If you really needed it, $1,000 for the WFT and a few hard drives should be quite affordable.
I do not like it, because it means having a cable dangling from the camera and a hard drive exposed to the environment. If you drop the hard drive, get wet, or loose the cable connection, you risk damaging the hard drive or halting the process of writing from the camera buffer to the hard drive. At least on the 1D, if the external connection is interrupted, the process of writing to the CF card also stops. When the price of CF media is so cheap, it is better to buy a memory card that is more durable than a hard drive, in addition to being smaller and much more lightweight.
http://www.pbase.com/arshutterbug/
It depends on what you mean by 'directly'.
If you mean: upload to the computer and saving it directly on the external drive (without using the iternal HDD of the PC) than a card reader and anything like Windows Explorer will simply do the trick.
If you mean without computer (laptop or PC) then it will be harder as both the camera and the external drive are designed to be just a slave of another device (PC) and not capable of directing another device.
All in my humble opionion of course!
If I seem to talk nonsense or you can't understand me, it's probably my English :)
The idea of backing up digital photos to a hard drive while traveling, without having to bring along a laptop computer, has been at the back of my mind for over a year. I'll soon be in Brazil for three weeks , so this question percolated again to the surface. Searching anew for an answer, I landed at this forum and found michelephoto's query. I think I may have found a solution to this that meshes with my requirements and sensibilities, although I'm not sure that michelephoto will also embrace it. It's probably not as direct or simple as she hoped for, for one thing. Another caveat is that I haven't implemented this already, so I cannot promise that it acutally works. Nevertheless, this scheme seems promising enough that I will be trying it soon, and I will certainly report on the outcome at this forum. Please read on.
First, some background. I use Apple computers and mobile devices only, so I have no experience with the Android OS, and only minimal familiarity with Windows. Anyone familiar with iPad is well aware that the idea of transferring data from the iPad to an external USB drive is only a pipe dream, as no version of iPad is equipped with a USB or mini USB port (a USB adaptor is available, but the range of external devices that iPad will recognize is restricted, and certainly does not include USB storage devices). So, I searched Google using the phrase "Tablet computers with USB port." Nice, it seems that virtually all Android and Windows tablets have at least a mini USB port. Then, I queried something like "connecting a USB hard drive to Samsung Galaxy Tab 3 SM-T210," which led to an interesting post (23 Aug 2013, user damnnew) on a forum at a tablet developer's website (xda-developers.com): SM-T210 or SM-T210R "doesn't support 'host mode' which is quite frustrating for those who like to plug in their USB devices"...but, "Galaxy Tab 2.7.0 does support this feature." This gave me a glimmer of hope, so I kept browsing. I next watched a YouTube video in which user "AndroidFixation" demonstrates that a Samsung Galaxy USB adaptor kit works well with a flash drive, but not with a USB hard drive (the attached HD is recognized by the tablet, but it does not mount the device and allow access to its contents). Next, I don't recall how, I landed at the support site for users of Toshiba tablets (http://support.toshiba.com/sscontent?contentid=3462040), where I found the following:
"Toshiba tablets require any external hard drive connected through USB to be formatted using exFAT. Many external hard drives by default are formatted NTFS and won't be recognized by the tablet when connected. Note: FAT32 formatted external hard drives can be recognized by the tablet when connected. No need to format to exFAT)."
This is followed by a tutorial that describes the steps necessary to accomplish this with a Toshiba Thrive tablet equipped with Android 4.0 (discontinued but still obtainable; current models are the Excite and Encore families of tablets), a Toshiba Canvio 750 GB hard drive, and a Toshiba Satellite P775D laptop running Windows 7.
The important point to note is that here's a tablet manufacturer that's providing its users with explicit technical information on how to connect an external USB hard drive to its tablets. Presumably, if Toshiba supports this, then it must also be possible to access the attached hard drive for data transfer - otherwise, why bother? Toshiba makes many different tablets, some that use Android and others that use Windows. I don't know if the information above applies to both operating systems on Toshiba tablets, or only one. Nor do I know if the simply remedy of merely connecting an external USB hard drive that has been properly formatted is also the missing link for doing the same with tablets from other manufacturers. This will require further investigation. But in the meantime, it is reassuring to know that there seems to be at least one legitimate (manufacturer sanctioned and supported) solution to this problem.
The above provides only half of the solution sought by michelephoto. Now here's the other half. If you already own a Canon or Nikon DSLR, this part is easy. Treat yourself to a CamRanger ($299). It's best if you visit the website, http://www.camranger.com, for all the details. In a nutshell, CamRanger is a small battery powered router that plugs into the mini USB port of your DSLR and transmits data over a WiFi network to your mobile device - Android tablet, iPad, iPhone, etc. It allows full remote control of ALL camera functions, including focusing and including Live View for video. It also allows you to automatically transmit your images to your mobile device "on the fly," either as thumbnail or full sized, full resolution images. Your photos or videos are always stored, as usual, on your internal memory cards. The advantages of this kind of setup are numerous and exciting, but I'll leave it to CamRanger to finish the task of selling you on this idea. Personally, I can't wait!
How about a camera like the Nikon D7100 which has 2 SD cards which can be used in backup mode?
thanks!
Check this out:
However, it's not under $100 and I doubtyou'll find something for that kind of money.
But for what this device does, I find it reasonably priced.
thanks!
Check this out:
http://www.wdc.com/en/products/products.aspx?id=1330
This still requires at least a laptop connected to the drive via wi-fi; it won't copy from an SD card on it's own. Check out the manual, it's detailed there. The OP is still better off with a stand-alone Portable Storage Device - these have the necessary OS built-in to allow copying w/o being connected to a host system, and can also be connected to a host computer as an external drive.
Mark
Yes i have a same question. It could be great for all single card slot camera users. you can allways put a tablet or disck to you backpac and make an instant photo upload during events (weddings, corporate). Anyone find out how to do this.
You have regurgitated a 6 year old thread. Do you think that the OP has been checking on DP regularly to see if he will get an answer. Do you think that he cares at this point. Do you have any reason why you even decided to regurgitate the thread.
Yes i have a same question. ... you can allways put a tablet ... to you backpac and make an instant photo upload during events (weddings, corporate). Anyone find out how to do this.
One method is to use an Eyefi card. With the Eyefi Mobi I can send jpgs (no RAW) to an Ipad Mini.
Seems to work okay but have not tested it extensively or tried it at an "event" - how much faster does the camera battery run down, does it slow shot-to-shot performance, etc.
There are other wifi cards - Toshiba, Transcend, ezShare.
And other methods/devices
http://www.cnet.com/how-to/how-to-add-wi-fi-to-your-dslr-or-mirrorless-interchangeable-lens-camera/
Good Day,
Roonal
