The problem isn't the focus, it's the tangent of the line cutting through the flower. That wouldn't be a problem if it didn't point straight down the middle of the flower. It's always good to be aware of your background and avoid tangents. It would have also been better if the line in the background was opposing the direction of the flower, instead of going in the same direction.You did quite well on the second one as you isolated the subject nicely. The composition of the first one is not as the background is to much in focus.
I'm sorry, I don't understand tangent, I looked up tangent in dictionary online it points to trigonometry description. English is not my first language. Also I want to clarify something, When I crop this image, what I'm thinking was the stem connect to the flower point to the dragonfly. Please clarify, I really want to understand betterThe problem isn't the focus, it's the tangent of the line cutting through the flower. That wouldn't be a problem if it didn't point straight down the middle of the flower. It's always good to be aware of your background and avoid tangents. It would have also been better if the line in the background was opposing the direction of the flower, instead of going in the same direction.You did quite well on the second one as you isolated the subject nicely. The composition of the first one is not as the background is to much in focus.
It's a term used by artists when discussing composition. A tangent is a line in the image that connects with another line or cuts across it in a way that is distracting. An example would be an image where the line of a door in the background exactly lines up with the stripe on someone's shirt or the branch of a tree seems to be growing out of someone's head. In this case, the line in the background exactly cuts through the center of the flower. It would have been better if it was at an angle to the flower not centered, rather than straight on down the middle.I'm sorry, I don't understand tangent,
