Geraint, You are missing the point. The presnt resolution test
was never designed to do what it is being used to do. It was
designed to test lens resolution, period. It has been said here that
in certain cases, they went to a finer grained film to make the
results valid. In this case, we are talking recording media with
random image capture, compared to a fixed grid, with the results
being greatly influenced by the grid alignment with the chart.
I don't have a lot of time messing with this, but I already know that
the score a camera comes up with on the present chart will be
changed to a large degree, if you simply rotate the camera 2 degrees
right or left. To use this test, you would have to have a heavy
jig, with the chart fixed in the jig in relation to the camera lens
mount, You would have to design the jig so that the camera was
held in place by the lens in such a way to keep it both pointed
at the correct center of the target, and so that the lens was
square to the target. These things are easily accomplished, even
if such a jig would not be cheap. There would then need to be
a way to line up the grid on the sensor array with the lines on the
target, so that you are testing the same thing on each camera.
At that point, you would have a decent test that would identify
both lens issues, and the ability of the sensor to capture this kind
of image. This is where things get kinda crazy. How do you align
the sensor grid with the lines on the target? How do you repeat it
accurately from camera to camera? The idea is for a test that does
not have as stringent operator requirements, because the test is
designed to to eliminate the variations except being reasonably
square to the target, and centered. For the record, this is not
for the D7i benefit. It is for my benefit. The present controversial
postings claiming a 40 percent advantage to the 707 were just
the cause of the timing. These claims are clearly wrong, but in some
ways, the results of the currently used test support this error.
As far as results, a standard deviation program that was run four
directions would leave little doubt on the radiating target. I think
the random dots target would plainly visable. The current radiating
target linked in the F100 thread shows the resolution change with
direction across the CCD very well, but misses a couple of things I
would like to see. A standardized chart that is an image of fine
grained wood with randomly placed color and texture targets would
tell us more than the present test does. Still thinking, reading,
searching, and trying to evaluate what would be the optimum.
David, I would have to have permission before posting any of the
wedding shots. It is my son's wedding, but that doesn't change
the ethics of posting things like that without permission. I will
tell ya, I managed about 80 percent usable images, but on most,
it is a good thing I used RAW. The shot I would post is from
the side, with the Willow over the top. Parts of the willow
are shaded, parts bright, and other parts are backlit. The effect
is kinda strange. If we had posed shots, I could have done
very well with the conditions and the surrounding scenery. As
it is, it was a shoot on the fly sort of thing, and even the good
shots have things like the other relative with the video camera
in the background. Full suits, tux's and such do not lend themselves
to long extended posing sessions outdoors when it is 98 degrees
where you are! I suspect that with the results I see in my files,
and knowing I had instant feedback, that the film shooters are in
big trouble!
Eric's comments are right on. I shot 101 shots in a garden at the
botanical gardens today, at 1:00 in the afternoon. The shadows,
backlighting, random sun and sunny water and white stone bridge
highlights were a nightmare. Add to that, the ceremony was under
a Willow, where many of the faces have foliage across them. The
miracle is that I managed to pull anything usable out of a non-posed
event at all under the conditions. I had a good time trying tho.
This is with a 2 year old camera. Using the cameras is what is
important, but understanding the truth about our next purchase
is also important.
Sounds interesting shooting Bob.Any chance of posting some of the
results of your travails together with the EXIF? Might do a lot to
demo where the limits of the camera are. When I'm trying something
difficult I never know whether it's me or the camera. (usually me!)
DaveMart
