What a nice vacation!! You definitely have to buy the B1.
My setup:
- Bogen Carbon One 3444 (4 Section) Tripod with carry strap and
spiked/rubber feet
- Arca Swiss B1 head with mounting plate for CameraBody
- Gimbal Sidekick with mounting plate for 70-200IS (my longest lens
so far)
My buying decisions are mostly influenced by my physical limitation
as I'm only 5'3" so I look for compactness in case I decide to go
on a photog trip someday or just plain vacations. I chose the 4
section over the 3 section because its only 20.5" long when folded
(4" shorter). But, at first, I also thought about it's load
capacity being reduced to 11 lbs (2 lbs less than your 441).
However, if you add up the weight of my D30 and 70-200IS (or even
the 100-400IS) it wont exceed 11 lbs. I don't see myself carrying
a 400mm 2.8 (11 lbs) on a trip but I could use this lens on fast
action indoor hockey games. Maybe a 400/f4 DO someday -- still
won't go over 11 lbs with D30 and will still work with Gimbal
Sidekick.
If you see yourself owning a 400mm 2.8 in the future, I suggest
getting Full Gimbal since the Sidekick application has a lens
limit. You should go to their website and find out. Then you
should also get a tripod with higher load capacity -- the Gitzo
might be it -- that is IF!
I'm tempted to get a 100-400IS but I'm not a real fan of push/pull
manual zoom -- just my preference but I'm sure the lens is great.
I hope Canon comes out with a lens similar to 70-200IS that doesn't
change in length while zooming. Maybe I'll save my money for a
400/f4 DO at the same time wait for it's price to come down a bit
and for my wife to forget all these crazy purchases since I owned
the D30.
BTW, what is your concern about the 400/f4 DO???
I know Michael's opinion, but wanted to hear from others who are
happy or unhappy with other set-ups.
I know I will get a sidekick, I'm pretty sure about the B1, but am
not convinced about the gitzo. I will go to the camera store again
tomorrow and play (once more) with the leg clasps. I am still
leaning towards the bogen carbon one.
By the way what set-up do you have?
I subscibe to Michael Reichman's Video Journal where he
demonstrated this setup at Bosque del Apache location shoot which
is how I came to know and considered buying it after exhaustive
research. Please read more at this link
http://www.luminous-landscape.com/bosque.htm Apparently, this
tripod setup is used by most wildlife photog especially bird
photogs.
Please email me for more info about the video.
-Alex
The acratech says it can go to portait mode and can be used with
the sidekick.
As I understand it the issues are:
Acratech: Lighter, unconventional design, a little cheaper.
B1: Heavier, industry standard, has eliptical ball to stop flop,
more expensive.
I haven't heard from anyone you actually uses one, except in a
couple of reviews.
automatic
