have you held one in your hands, Tom? do you know that for sure?Furthermore - getting a GXR with 50mm will need super-sized pockets.
or are you just trying to "balance" everything out...
We all may need barbour coatsMy pockets are just not big enough to fit a GXR and 50mm (smile)
Tom Caldwell
I am always trying ...
--Don't bother, you have just made it to my ignore list....
if i will have new impressions, i will let you know.
Andrew
Enjoying my LX3!
It's a bit disappointing that the A12 isn't an internal focusing lens, but at least it has other redeeming qualities. It would be interesting to see a DPR test of this lens. It would probably give the Oly 50/2.0 macro a run for its money.Welcome to the forum!
thanks!!
I have a few questions that maybe you could answer:
1. Does the A12 extend when focused to the minimum distance?
-araound 3.4 cm
Still decent. Far higher than any focal-plane shutter.2. Is it possible to use the flash when the A12 is set to to its maximum shutter speeds (1/3200)? Do you get correct exposure?
- not with 1/3200 but with 1/1600
Thanks! I appreciate it3. If you set f/5.6 and zoom the S10, does the aperture stay at f/5.6, or does it "fluctuate" above and below?
- will check later
What is not amusing, and is clearly not acceptable, is for you to parade your prejudices about a nationality. But then, luckily, it reveals more about you and your mentality than about the person you are attacking. And what you've certainly shown is that your mentality is the opposite of that of Voltaire, since you're the one trying to exhibiting prejudice and narrow-minded in trying to ostracize Pangloss....I found it amusing that someone who has the handname of Pangloss would actually criticize someone else handle as suspicious !!!
Only a French could do that
also I know how the French mentality works but I think there is something that you should learn; It is called the benefit of the doubt !...
especially if you are going to use a reference to one of the great thinkers who made a point to fight ostracism and narrow-mindedness
Hello MitchWhat is not amusing, and is clearly not acceptable, is for you to parade your prejudices about a nationality. But then, luckily, it reveals more about you and your mentality than about the person you are attacking. And what you've certainly shown is that your mentality is the opposite of that of Voltaire, since you're the one trying to exhibiting prejudice and narrow-minded in trying to ostracize Pangloss....I found it amusing that someone who has the handname of Pangloss would actually criticize someone else handle as suspicious !!!
—Mitch/Bangkok
http://www.flickr.com/photos/malland/sets/72157622521614095/show/
Don't worry too much Harold. Everyone except Mitch knows you are FrenchHello Mitch
I thought everyone here knew I am French so I thought they would get the irony in my comment. Apparently , I was wrong !!
C'est le comble!Hello Mitch
harold
Can I be French too? Maybe not, too much Russian heritage, but pure Americano.C'est le comble!Hello Mitch
harold
—Mitch/Bangkok
