DezM
Nice changes on all and I like the gradient, smooth look that you applied to the sky:
Dez
http://photos.dezmix.com
Dez
Malch, I am not an expert on panos although I've done a few. I noticed when doing a panorama of a subject that's relatively close by, if I pan from one spot , I will get the barrel distortion effect that Chris got in his first pano similar to this:Chris: Terrific collection of panos. How satisfying it is to get home from vacation with some great panos like this.
Dez: Can you discuss your technique some more? I get the general idea but how do you determine when to move and when to remained fixed? And how far do you move?Also, the barrel effect on the building comes from panning this from one spot as opposed to moving along a straight line w/overlaps as I've done w/my panos that you've seen before![]()
I guess the concept is simple enough but I don't have the slightest clue about how to execute it in practice :-(
Thanks Dez, very helpful illustrations. I "get it" well enough to try some experiments of my own now.But if I walk a straight line, parallel to my close subject, I can create a natural looking pano. What I did here was moved to my left 2 paces along the straight curb of the sidewalk and shot. I used the curb as my guideline. I made sure that I had enough overlap and the stitch came out the way it was supposed to with little or no distortion:
Your welcome. I just re-read my paragraph and I should've included that after taking 2 paces to my left, I repeated this until I went past the subject.Thanks Dez, very helpful illustrations. I "get it" well enough to try some experiments of my own now.But if I walk a straight line, parallel to my close subject, I can create a natural looking pano. What I did here was moved to my left 2 paces along the straight curb of the sidewalk and shot. I used the curb as my guideline. I made sure that I had enough overlap and the stitch came out the way it was supposed to with little or no distortion:
And that's a yes on the overlap. I think most or all new pano shooters (me included) tend to underestimate the amount of overlap required for good problem-free stitching.
--Your welcome. I just re-read my paragraph and I should've included that after taking 2 paces to my left, I repeated this until I went past the subject.Thanks Dez, very helpful illustrations. I "get it" well enough to try some experiments of my own now.But if I walk a straight line, parallel to my close subject, I can create a natural looking pano. What I did here was moved to my left 2 paces along the straight curb of the sidewalk and shot. I used the curb as my guideline. I made sure that I had enough overlap and the stitch came out the way it was supposed to with little or no distortion:
The key is to be uniform, relatively parallel to your subject & level and have enough overlap.
But I want to add that at times, I do find that distorted look appealing as in Chris's case in photo #1.
Dez
--Nice changes on all and I like the gradient, smooth look that you applied to the sky:
Dez
--Thanks for posting the nice panos! I had another look after the critique by Dez and will use this info in the future. What a place to practice your pano skills!
Ron
--Great series of photographs, you must be pretty pleased with the results
I can only get better...!
--Chris,
Excellent work. Your prespective make the panos that much more compelling.
A suggestion. Have you shot a pano like this HDR stacked prior to stitching?
The outdoor ones, especially the first have some very hot and cold spots that could tighten up a bit that way.
Great job...
--Great picture believe me
this is what I thoght
Cariboou
Cameras: Nikon D200 - Nikon F2A - Lens Nikon Zoom 24-120 - Lens Nikon Ai 24/2.8 - 55/2.8 Micro - 105/2.5 - 200/4 - 300/4.5 - Flash: SB800 - Metz 45CT1
Here my gallery photo: http://www.Caribooua.zenfolio.com
--just beautiful work Chris. I love the pano over your head that is soooo cool. I am sure that your stunning pictures have inspired quite a few others to get out there and try too....I know I will .
Thanks for sharing.
Barb
Barb
http://maraya.smugmug.com/
Interesting, so why the distortion that? Did you tilt the camera up while panning?I have found that walking parallel to your subject and the overlap rules don't change from one technique over the other. Your viewfinder will tell you how far you need to walk to overlap and the farther you are away from your subject will have the biggest impact on how far and how many frames. Eg. In the shots Dez just showed us and my example below a sidewalk or street gives a good straight line for walking along. However in my first example that building is maybe 1,000 feet long and I was really far back. I am estimating I would have taken 15+ landscape shots to fit that all in and walked the length of a football field.![]()
I was probably 40 to 50 away from that building. You were considerably further away from your subject. But the distortion is similar.Dez - It is also interesting to compare the level of distortion in your street shot vs my building shot. I was considerably further away from the subject than you and level of distortion shows that.
That's correct and I learned the hard way when I first started doing them. The more overlaps, the more 'level' frames and the more control points the stitching software will use for a proper stitch.As Malcolm mentioned most do not overlap enough, myself included sometimes (hence the reason I showed the last shot!But overlapping really is a case of you can't overlap enough. The stitching software is so advanced that the more frames you have the better latitude to correct an error and quality of the pano IMO.
Sorry wasn't very clear was just trying to say that it appears the closer your are to the subject the greater distortion and warp effect. The further away from the subject the distortion is still present just not as great.Interesting, so why the distortion that? Did you tilt the camera up while panning?I have found that walking parallel to your subject and the overlap rules don't change from one technique over the other. Your viewfinder will tell you how far you need to walk to overlap and the farther you are away from your subject will have the biggest impact on how far and how many frames. Eg. In the shots Dez just showed us and my example below a sidewalk or street gives a good straight line for walking along. However in my first example that building is maybe 1,000 feet long and I was really far back. I am estimating I would have taken 15+ landscape shots to fit that all in and walked the length of a football field.![]()
Exactly the distortion is similar but it looks like it is more pronounced in your shot since you were closer. In fact look at my last shot as a good example... all the subjects that were close are much more distorted than the subjects further away.I was probably 40 to 50 away from that building. You were considerably further away from your subject. But the distortion is similar.Dez - It is also interesting to compare the level of distortion in your street shot vs my building shot. I was considerably further away from the subject than you and level of distortion shows that.
Thanks!That's correct and I learned the hard way when I first started doing them. The more overlaps, the more 'level' frames and the more control points the stitching software will use for a proper stitch.As Malcolm mentioned most do not overlap enough, myself included sometimes (hence the reason I showed the last shot!But overlapping really is a case of you can't overlap enough. The stitching software is so advanced that the more frames you have the better latitude to correct an error and quality of the pano IMO.
BTW, love that mural pano! Well done.
--NIce photos! As you know i preyy much gave up on panoramas, too much hassle for me.... But your stitching is flawless.
The only think I'd mention is that most of the shots look little too contrasty with no shadow detail. ( deep blacks look too black pretty much) I think Dynamic range could be easily improved without loosing the conrasty "pop" you're looking for.
http://www.infiniteartphotography.com
http://www.pbase.com/jps1979/galleries
