Reading Sony Style.com, it says that F20am flash work WIRELESSLY only with A900 camera. Why is that? The spec sheet didn't say anything about A850, but I'm assuming A850 should have this ability as well since its a A900 lite.Hi,
does it work with the f56 as wireless? It would save alot of money in getting another F56.
I'm using this flash on vacation right now with an A850, bought it at Adorama just before I left. Unfortunately I haven't really put it through its paces but so far it's idiot-proof. Size is about like a deck of cards. No lazy eye so far, I'll try to test that a bit more for you today. Takes 2X AA confirmed.
Thank you. Waiting for your mini-review. How is the re-charge rate using just 2 AA?
Yep, that was originally posted here a while back. It's the whole reason I bought the flash...Apparently the pivot switch can be fooled also to fire in the down position. You simply need a small magnet straped/taped onto the flash pivot to keep it on. Then you can use it as a macro flash.
