White text on black background
Darryl Yee
New member
San Diego, US
Great reviews here and a wealth of information in the forums, but is it just me or does the small white text on a black background give you a headache? It is too contrasty which makes it hard to focus and read quickly. Is there an option to change it?
You can reverse the colors by "selecting" the text. Not a perm fix but I do it sometimes on large chunks of text. Or on those artsy hard-to-read pages with navy blue on black. I don't really get it. Why do white on black anyway. Ever see a book printed like that?
my browser is set to ignore the page designers' whims and show a light gray background with black text. I can select the appearance in Internet Explorer and I suspect you can in other browsers as well.
Patrick T. Kelly
Oaxaca, Mexico
No - but of course a computer screen is not the same as a book page.
For a reason that I'm afraid I haven't enough know-how to explain technically - you just seem to get a LOT more glare off a computer LCD screen (or I suppose a monitor...) than you would do off any sort of white page with print.
Since they're both Black and White only , I just can't explain.. but that's how it is .. to me anyway .. depends on eyesight maybe , but I'm sure a lot of folk find the same.
eric-UK
Historically, computer screens had a tendency to spill light from bright areas into darker ones. So black text on a white background would become lighter and thinner than intended, and consequently be difficult to read. On the other hand, white text on a black background would tend to be come a little thicker rather than thinner, and hence remain readable.
In the case of printing, the problems are reversed. Attempting to print white text on a black background can result in the ink spilling from the dark areas over into the text itself, resulting in illegible text, unless the printing is of extremely high quality. Generally it is only used for headlines and text in a large font where the ink spilling over into each letter is relatively less of a problem.
Modern computer monitors tend to render edges more sharply, so some of those problems have been reduced. However, I still find black text on a white background is a source of glare, and prefer a dark background with lighter text.
It's still the case that what works on a printed page is not necessarily the same as for an illuminated screen.
Peter
Peter
Peter -
All sounds very technical but indeed that is exactly right .. as it is seen
Actually, in computer work I rather like and use a lot of yellow text on black - that does look very legible I think - and of course IS used here on Forums to some extent - and it looks good to me.
eric-UK
The big difference between paper and lcd is that one is a source of light and one is a reflector. Still, black on white seems easier to read.
There's no arguing taste, of course. Having said that... the difference in the amount of glare on the screen in front of me right now between this white box and the black part, is striking. I can barely make out a light behind me in the white. In the black I can easily see my face (aaaarrrrgh!). That is the glare mentioned above, right? I don't at all understand "...find black text on a white background is a source of glare". Maybe I don't understand what is meant by "glare"?
Yellow on black is better than white on black.
As has already been mentioned, your web browser (which one do you use?) should have options to change colors. Your problem may also be due to setting your monitor's contrast and/or brightness settings too high. Many people do this because they think it improves the appearance of pictures/images, but it usually makes text harder to read, and if done to excess, often makes text blurry. Have you ever had your monitor calibrated and profiled?
http://www.drycreekphoto.com/Learn/monitor_calibration.htm
