If you had to pick ONLY ONE landscape lens, which would it be?
12-24 DX ... you can always use your other lenses (longer) for different vantage points, but (I) need to spread it out more than not.
jfs
Nikon D40X & D90 user
I would likewise choose a medium telephoto too. Like a 85mm.
Kam
I guess it depends on how you do it.
When I go into the rainforest, I used to take a 50mm on my RB67 or a 24 on a 35mm. Now I will take the 127mm on my speed graphic 4x5 (about 35mm eqiv35), my superwide pinhole camera (about 18mm equiv35 on square 120) or my 35 f2 on my d2x(because I like to stitch : )
I go for a slight wide usually, superwide is fascinating but I find that I see in a more narrow FOV usually
remember that you will probably be stopping down and on a tripod , so the performance of lesser lenses may be better than they are given credit for, for your purpose. (eg my 15-30 sigma was amazingly good at f11, which is a good aperture for some deep wide angle perspectives)
There is landscape and then there is landscape. Also helpful if you share what camera or at least Fx vs Dx. I am assuming your D200,lots of good choices for UWA, WA and every thing up. 300 2.8vr works also
Tom
http://taja.smugmug.com/
Regardless of your format, DX or FX, truth is simple: Depends on the scene and what you want to say. UWA and Tele are all options on the table. I like UWA, WA, normal, and Tele depending on scene and your view of what you want to capture.
http://www.flickr.com/photos/22388579@N08/
Ok...
Using a D200.
Will be taking a trip up the Pacific Coast Highway, so the pictures will be beach and mountain coast lines. Then I will head over to Yosmite national park and take pictures there for 3 days.
Also, if anyone can recommend a ND filter for the above application please?
I too recommend the very expensive and large 24-70 f 2.8 otherwise, probably the 16-85 but like last poster said, hate to tied to one lens. How about inexpensive 16-85 AND 70-300?
...and if you like UWA, then get the 14-24/2.8 or 12-24/4 (if you will take the D200). For the coastline, I think an UWA is really good. For Yosemite, the UWA will also work, but you might want a standard zoom or medium telephoto too.
The first two images are on the PCH (Big Sur) with the 14-24 @ 14mm and the next few are at Yosemite (also using the same lens).
Ultimately just go with the kind of photography you like to indulge in- the possibilities are limitless in both these places. Have fun! :-)
Nikhil
http://www.lihkin.net
25-50 on full frame . .
