WHICH version of PHOTOSHOP CS4 IS UNaBLE TO INTEGRATE WITH LIGHTROOM 2
Susiewong
Well-known member
Melbourne, AU
ADVICE WHICH PHOTOSHOP CS4 NOT BE ABLE TO BE INTEGRATED WITH LIGHTROOM 2
Sue BLOCK , Aug 11, 2009; 12:01 a.m.
Hullo
I have a Mac OSX 10.5.8
Lightroom 2
I have an opportunity to purchase the Educational version of Photoshop CS4 or the Standard version of Photoshop CS4
I am wishing to use Photoshop within the Photography realm only
Can either of these versions be fully integrated with Lightroom 2 ? i e plug-ins, droplets etc. etc.
What would be the disadvantage of not purchasing Photoshop CS4 extended?
thank you
Susiewong
Yes. I believe that it makes no difference whether an Educational or commercial license is used, it is the same software. There may be some license restrictions about commercial (for-profit) use of the Educational version.
I am not aware of any disadvantage, for normal photographic image editing. If you needed the extended functions, you would probably already know about them - say if you are doing 3D CGI, video compositing, something like that.
Having the Extended version does mean that your upgrades will be more expensive, for ever! The same is true if you buy a CS suite pack rather than a stand-alone program: you will always have to pay to upgrade everything as a group - you can't later separate the set - even if you don't actually use the other programs.
RP
maybe the Caps Lock isn't broken - this post seems to have snagged your attention, and mine... not always easy to do here ;-)
RP
