Hi there Andreas. I have a question for you and others who have more experience with this.
The user's guide says about the manual focus: "When recording still images, the LCD image is zoomed in 2x and the focus mode indicator is displayed. When a sharp focus is achieved, the image returns to normal and the (F> (manual focus) indicator changes from yellow to white. When recording moving images, the image is not zoomed. You can adjust the focus distance from 13/16 inches (2 cm) to infinite."
Now, my questions/assumptions are:
1. My (F> indicator changes initially from white when I am not touching the focus ring, to yellow as soon as I touch the focus ring and try to turn it. So the yellow color is simply to indicate that the focus is being changed. Is this correct?
2. The yellow focus indicator is NOT an indication that you have a good focus or even a bad focus, is that correct?
3. If the above is true, then how do you KNOW that you have a good focus? For example, if you are in a low-light situation, I would imagine that I'd have to simply try to guess the distance involved in terms of meters, correct? In this situation, you cannot tell even with the LCD zoomed in by 2x that the image is or is not in focus, is that your observation?
4. The F505 used to have the little Left and Right arrows on either side of the green dot. So the dot served as an indicator that the focus was achieved. This is not the case anymore. The green dot now lets you know that exposure information has been calculated, is that correct?
These questions are posted to Andreas, but any of the others are free to answer it. I am not disappointed in this mode of operation. I simply want to understand it better so that I get the best use out of it.
Thanks for any help you folks can provide.
Hi,
For me the improved manual focus is one of the most useful progresses
of the F505V (compared to the F505). It seems that the distance
specification
is accurate. So, especially in extreme low light conditions (where is no
way to
lock for the autofocus) i set the distance, set an suitable shutter time and
the result is great!
