I have the s330...Is the tungsten setting in white balance the same as incandescent on other models? Also, what is the fluotescent H setting used for.
regards, Canbec
Yes, it is the same as the standard incandescent bulb.
The fluorescent H setting is for those daylight-type fluorescent bulbs. If you're not sure which you're working under, switch back and forth between the two types, and the results will be apparent on the LCD monitor.
setting used for.
regards, Canbec
on the LCD monitor.
setting used for.
regards, Canbec
