Johan112
Well-known member
Do you use the intelligent exposure? I've been using it in 'normal' most times so far when I'm using aperature priority, but I tried now to take some pictures with and without and can't see any difference.
It really doesn't matter whether you use it in 'A' as you say you do or 'P' or 'S' or a scene mode... It's useful in all modes & really depends more on the lighting of a given scene.Do you use the intelligent exposure? I've been using it in 'normal'
Lx3Fz50Fz30C8080wzE100rsC2100uzThe Amateur Formerly Known as 'UZ'pShoot'ERS' 'Happy Shootin' Comments, Critique, Ridicule, Limericks, Jokes, Hi-jackings, EnthUZIastically, Encouraged... I Insist!
* rrawzz'a'gmail'dot'com * http://www.pbase.com/rrawzz *
Are you sure you're not confusing intelligent exposure with intelligent auto mode... They're two different attributes....It works better than any automatic exposure system I have used. You
give up raw file format though. jpeg only.
Yes now I've seen it. It looks really strange, like it is redrawing the picture(LCD). I thought before that it was used all the time(then I hade it turned on) but it seems to have to be a really big difference in light for it to be used. You can see then it's in use too when its symbol turns yellow for a while.On hi, if you watch the LCD as you slowly pan in & out from dark &
light, you can actually see a sort of texture, for lack of a better
word, roll across the screen like a wave of lower contrast... It's
weird lookin' & hard to explain...
Your the 2nd person to mention that & even though i've had some level of I-Exposure enabled for the past several months. I still haven't seen the icon turn yellow but then again, I often have all the display info turned off....when its symbol turns yellow for a while.
If I point the camera half on the computer screen and halv outside it start for me every time, turns yellow and redraws the LCD like you described.Your the 2nd person to mention that & even though i've had some level
Aha interesting. I've seen the 125 ISO sometimes but didn't understood why that happended. I wonder if it says somewhere in the exif data that it's been used too?FWIW, the Iso is also a giveaway that it was in use... If you take a
shot with the ISo locked @ 80, if the I-Exposure kicks in, it'll be
125iso in the exif even though you had it locked @ 80.
Maybe PhotoME exif reader will show if it is in exif.. I've not checked but that Exif reader covers just about everything in the exifAha interesting. I've seen the 125 ISO sometimes but didn't
For What It's WorthNot important, but what does 'FWIW' mean?
ThanksFor What It's WorthNot important, but what does 'FWIW' mean?
Probably a little of that but it's also specific area selective iso boosting in the shadows too, if I read Panny's definition of it correctly... They describe it in detail somewhere on the Panny site...rite?
Thanks Russ. It was that easy! Now I feel stupidno text
