marsbar
Leading Member
Yeah I just don't get it, having video on DSLR would be a dream because of lenses, but crippling it so much... what a joke. I have a HF10, and the fact it can can do better than 5D Mk II in terms of functions is funny.I can live with 720p at 30fps, but these other problems pretty much
makes video a useless feature in this DSLR for me.
This is true at least when using LV contrast detect AF, but is it the case with 5D Mk II? that really sucks.. Focus problems - In video mode, when you press the focus button, it
will make the video over-exposed during the focus duration. (This is
because the contrast based detection needs more light to focus.)
Again so true, bigger DSLR lenses can focus fast enough for still frames but for video it need to be very fast or else some frames will be OOF. I guess the lighter lenses that camcorder use, as well as high end 2/3" camcorders have that advantage. So people that are used to photo, but not video will get very frustrated.. No actions - Focus speed is very slow compared to a cheap
camcorder. Parents can't capture their young kid running around.
Yeah wind cut filter is very useful, it's surprising how much difference it can make.. No outdoors video - There's no wind filter, which means the wind
sound will be a problem in your video.
Boy your really slinging mud now!. No music recital - No external port for microphone. So you have
high quality graphics to go with mediocre sound.
Ok there might be a compromising work around for this. Use the DOF stop down trick, remove lens, tape over contacts, reattach lens. This of course means no AF, or any info from lens type your using, for PP adjustment. But it means you do have a manual Av mode that is possible. But it's very limiting, and not practical on the field.. No artistic video - Can't set aperture/shutter/ISO. So you can't
get that cimema-like shallow depth of field with your larger aperture
lenses (unless the camera happens to use it wide open).
Again DSLR lenses are made for shooting still photographs, so you draw a very valid point. Hay this could cause a price surge of the EF 35-80mm f/4-5.6 PZ lens in the used market!. No smooth zoom - Can't zoom smoothly like a cheap consumer
camcorder. Well, this is an inherent problem with all DSLR, not just
Canon.
I'm still gonna look into buying the 500D, not because of video, but I would like a camera to convert to Infrared that has contrast detect AF, and that is not my 50D.Other than that, it's a fine tool for capturing still images.
