--I have the S5 with 50/1.8D and 18-70 Nikon zoom and will start
photographing orchids in the wild (this summer). These lenses will
reach maximum reproduction ratios of 1/6.6 and 1/6.2 respectively in
macro photography. But I guess this refers to full frame cameras like
the D700. With the S5 does that mean I can achieve 1/3.3 and 1/3.1 ?
The magnification ratio has nothing to do with the crop factor (full frame or otherwise).
Magnification ratio is defined as image size on sensor (or film): size of subject.
So if you have an image of 1cm on the sensor from a subject of 6cm, you have a magnification ratio of 1:6.
Crop factor does not affect this. A cropped sensor is simply a crop from a larger area, not an increase of image size. Your lenses give the same magnification ratio on the S5 as on the D700 though the S5 has a tighter crop.
If so, is that OK for flower photography? I am thinking of buying the
Micro-Nikkor 105/2.8 VR but will wait for any comments from you out
there. Thanks!
The sensor of the S5 is 2.3cm long. With a lens whose magnification ratio is 1:6, you will fill that 2.3cm length with a subject that is approx 14cm long. Your flowers may be smaller than this and the magnification ratio may therefore not be adequate.
True macro work uses magnification ratio of 1:1 or greater (e.g.2:1) and is not usually needed for flowers. Flower shots are usually closeups, not macros, unless you want to make abstract shots of the parts of a flower (stamens etc).
One lens you may like to consider if you want really beautiful tone, colour and bokeh in closeups of flowers is the Zeiss 50mm f/2 Makro Planar. It is misnamed as a Makro because it cannot achieve 1:1. However, it does achieve 1:2 and that is more than adequate for closeups of flowers.
Here is a series of mine, taken with the Zeiss on the S3.
http://forums.dpreview.com/forums/read.asp?forum=1020&message=29161242
The first image in that series is not an orchid but it will help you to imagine how well it would do for orchids.
I have a home on pbase
http://www.pbase.com/claypaws/
If you have the time to look
