Now that some people have mentioned it, I don't believe I've actually
looked through the viewfinder of the D700. D300, D90, D80, 40D, yes,
and honestly, I didn't have a problem with the viewfinder image in
any of those. Of course, I was in a brightly lit store, so it might
not count. Perhaps at this point, if I'm not going to get the D700,
I have not played with the D80 but I briefly looked through the D90 and the D300. Of course, I have played with the D40, Sony A200, 300, 350, Pentax K200D, the Oly E-3, E-30 and my own lower range Olys.
1. The store lighting does not count. It is not the brightness of the scene, it is how bright and large as well as detailed the viewfinder looks.
2. Of course, for that you need a working lens fitted, preferably the same f/no as all the models you are going to look through, you need to set the dioptre adjustment correctly - I can blush that I was making a split last minute decision and went the Oly way because the Sony A200 viewfinder looked blurred. When I was downstairs in the mall in another shop handing over the money, I realised my evaluation error - I had not figured out how to twiddle the dioptre adjustment on the Sony A200. But I'm happy I went the Oly way.
3. You should and must look through the cameras you mention, plus the lower range ones. If you cannot grasp what we are talking about, then like we used to say in hifi, buy the cheapest one that you can't see/hear the difference.
4. There is a big difference between the D300 viewfinder for example and my Oly E-510 viewfinder - I can't focus manual focus lenses easily (even though that's my favourite pasttime) because it is hard to discern the point at which focus is correct. The D300 viewfinder looks like someone put good spectacles on a near sighted fellow or you stepped from looking at your normal size telly to these modern 50 inch HDTV flat panel televisions.
The difference is significant - even though I don't put that facet at such a weight for my personal choice that is overwhelms other facets.
as seems to be the case now, I should avoid looking through it, that
way, I won't know what I'm missing!
Nope. Looking is free. Taking it home is not. Do the free thing.
Ananda
http://anandasim.blogspot.com/
