D90 with E-Series 50mm 1.8 problems
ozpaul
Active member
Adelaide, AU
Hi I have a couple of old lenses from my wife's camera which I have been trying out on my D90. The Nikkor F ?series 135 f2.8 which seems to work. However the E-Series 50mm 1.8 does not change exposure at all when the apeture ring is turned and also one needs to use ultra fast shutter speeds in bright light. I am a little perplexed as they both came form the same Nikon FG SLR and I have not read of any issues like this. Any thoughts? Thanks Paul
photos at http://www.flickr.com/photos/ozpaul and http://www.trekearth.com/members/ozpaul
D90 won't meter with non-chip'ed lenses. You have to use them in manual mode, where you'll be able to control exposure time & iso from camera and aperture from the lens.
http://www.flickr.com/photos/gearporn/
-equipment in profile-
Probably something happen to the aperture. Does the aperture stay open when you take the lens off the camera and set it to anything but 1.8?
yeah, okay, wow @ those guys above. i think it's a safe assumption that you understand the d90 will not meter with those lenses -- any reading of your post at all would tell someone that.
hopefully i can provide some real help.
to work.
hopefully, since both lenses came off your wife's FG, they're both AI/AIs lenses. please try to confirm this, as if you're using a pre-AI lens, you CAN DAMAGE YOUR CAMERA. do the aperture rings look the same or very similar, with a ridge that sticks out towards the camera for a portion of the circumference? if the aperture ring is the same width all the way around, do not mount this lens to your camera.
on all AI/AIs lenses (including the series E), the aperture of the lens is strictly controlled by the aperture ring. the AI lenses are not designed to have their aperture controlled by the camera. but even the AIs (and series E) were designed to be used this way (by the FA and similar cameras), the aperture blades still snap to the smallest aperture unless there is a camera behind them to hold the DOF-preview lever in the "open" position.
when the lens is unmounted, and set to f/22, you should be able to see all the aperture blades and the aperture should be tiny when you look through the lens. if you then move the little lever on the back of the lens, you should be able to manually open it. mounted, the DOF preview coupling should hold the lens open until the picture is taken, when the iris will contract to whatever setting corresponds to your aperture ring. i have used AIs lenses (including the 50mm 1.8 series E) on both the d70 and d200, and this should be the way the d90 works as well.
if your camera is forced to take pictures at f/1.8 regardless of the setting of the aperture ring, it means one of two things has gone wrong. either your camera is broke (DOF coupler doesn't relax when the shot is fired) or the lens is jammed. considering that the other lens works fine, it's probably not your camera. mess with the aperture ring and DOF lever on the back of the lens, unmounted, and see if it behaves as described in the paragraph above. if it does not, and just stays open, your aperture blades are probably jammed, or stuck with oil and the lens is trashed.
if that's the case, don't feel to bad. they're incredibly inexpensive (but high quality!) lenses, and easily replaced. you can get the the AI or AIs long barrel version (the best versions) for about $60. or the AF-d version for a little over $100.
Series E lens are "AI" lenses. They won't meter on a D90. (They
will on a D200, D300, D700, etc.)
actually, all the series E are AIS, not AI.
picky picky picky. technically, AI just refers to aperture indexing, and not the business about which scale the aperture coupling works on. so even though we call all the pre-s AI lenses "AI" and the post-s lenses "AIs", all AIs lenses are also technically AI. one is subset of the other; they're not two separate sets. sort of like how all AF-d and AF-s lenses are also "autofocus" even though we use "AF" without the suffix to mean the pre-d and pre-s lenses.
and in any case, i would have commented on how his post was rather irrelevent. the OP doesn't seem to care that he doesn't have metering. he's asking why his lens iris isn't contracting, not why his camera doesn't know how to expose properly with it attached. he's turning the aperture ring, and the lens is not stopping down when the picture is exposed.
1.8?
I think the answer to you question is yes... and the aperture ring is quite loose, like there is no mechanical action. In fact, now I am thinking about it, we had some serious over-exposure problems many years ago (in the 80s) wiith the FG on trip around Tasmania and this put me off SLRs altogether... So much walking for so few decent photos! I bought a little Canon automatic p&s... Perhaps the lense was in fact faulty way back then. (PS I know about the manual mode stuff..) Thanks for your suggestion. Paul.
