liquidsquid
So I have my replacement G1 for the other one that managed to somehow get a strange fault which even currently has Panasonic scratching their heads... That is another story.
A thread that hit 150 was talking about image muddiness, and how the person saw it in the foliage and other fine details in the background of landscape images. Basically they are seeing the G1's noise reduction at work, and if it is bothersome, turn down the setting in the film mode they are using if you want to keep the detail in the camera JPGs as high as possible. I always run the cam with NR turned down in all film modes. If noise is a problem in an image, I will target it with a raw processor anyhow.
Note: Not a perfect test, but a description of what muddiness may mean, and how to not get smudged foliage in some situations.
For example, ISO800, G1 with default +0 settings in film mode. You can see the chroma smudging used for NR at work here where the stick's color exits the sticks outlines, this is a common NR technique:
This is the same image using SilkyPix with fairly aggressive NR but favoring the detail:
With ISO100, things are different, the in-camera NR is not as aggressive, and I don't notice much difference between the in-camera JPG and the SilkyPix image until I start applying some sharpening. IMHO the SilkyPix sharpening is much more natural to my eye, but I don't see muddiness in either image.
ISO 100, all default film mode settings, same scene, different crop as above. Moderate sharpening applied in post.
Silkypix of the same with "Pure Detail" sharpening moderately applied.
My pictures...
http://12.168.34.68/photos/default.asp
http://www.markwyman.com/photos/default.asp
My pictures...
