Case for s100fs
ukwoody
Leading Member
Pembrokeshire, Wales, UK
HI all, which camera bag do you use/recommend for the 100fs? I want one that will also take a couple of accesories (like flare guard), along with extra batts etc?. I prefer the rectangular case type rather than the downward facing type.
cheers
woody
After 10 years of picture taking - you'd have thought I'd have learnt to remove the lens cap...
... I use a padded Sony bag which came with one of my cameras. No idea what the model is but it's blue. Holds the S100fs perfectly with hood attached.
Also holds CPL and extra SD card. It would also hold an extra battery, however, I've never had a problem with the battery running low. I can shoot Over 450 images and still have power. Caveat - I rarely use the LCD and the flash hardly ever.
Rgds, Dave.
Have fun - take lotsa pix.
http://www.redbubble.com/people/pixplanet
S100fs Examples - http://www.pixplanet.biz/Posting-stuff_5.htm
Post processing (PP) Tips - http://www.pixplanet.biz/Posting-stuff_7.htm
I've tried a few bags, and all have their merits.
Easiest access would go to the classic shoulder bag. I have a Lowepro Nova 1 (I think) and it holds the cam with a lense on it, along with some accessories. If you want to carry an external flash and a Raynox around with you, check this one out. They make several dozen different models, so one is likely to suit.
I also have a Lowepro Off Trail 2, which is a nice toploader that holds just the cam and lense in the main bag with an excellent shoulder sling. It comes with a pair of sidecar lense cases that can hold smallish lenses or normal sized flashes. I like this one to stuff in my luggage and use while around town.
Second easiest access goes to the sling bags. I have a Lowepro Slingshot 200, which holds the cam with lense and several extra lenses and other accessories. There is a smaller one and a larger one in the line. The smaller 100 would probably be suitable. These carry like a backpack with one strap and they slide around quickly with a portal unzipped for fast access to the cam. Not bad to use but a pain to get at the accessories. Easier on the back that the shoulder cam for long days of trekking.
Most equipment carried belongs to the backpacks. I own three of these.
One is the Compudaypack, which has a comprtment at the bottom for camera stuff, and a moderate sized compartment above for travel items and a few clothes. I used this bag for a trip to the UK where I took a tour to Stonehenge and got to run around inside the circle for an hour. I brought the D2Hs (huge pro cam) and the D70s, along with the 18-200VR and the Sigma 10-20. It all fit and carried quite well. Oh yeah, the laptop was in the back. However, my back was a wreck at the end of the day because this really isn't a properly designed backpack, for example there is no chest strap so the shoulder harness slips off all the time.
My primary carrier for heavy travel is the Lowepro Computrekker AW ... this is a great all weather bag (has a protective water proof cover than can be deployed in seconds from a pouch in the bottom) that holds massive equipment. Last year, I travelled to my old home town with my D2Hs, D70s, 300 mm F4 AFS, 18-200VR, Sigma 10-20, Sigma 105mm, a flash and lots of other accessories. Worked a charm. It also carries a laptop in the back. This year I took the same back to the UK and carried the D300, the 18-200VR, the 105mm 2.5 AIS, the 28mm 3.5 AI, two flashes, and a bunch of other stuff. And my laptop of course, as this was a business trip. Access requires that you take the case off and open it up, but one quick zip can do it so it does not take long.
For that same UK trip, I picked up a used Lowepro Micro Trekker 100, a very small back pack that can carry a camera and a few lenses or a lense and a flash. It is a tight squeeze and I ended up not bringing it. Not sure what I will do with it. I like the bag, but I also like to carry more equipment than it can handle. If you want a backpack, this would fit the S100fs and a few accessories very well. And I think Best Buy sells these as well ...
Anyway ... you probably don't need the big bags, although they can carry a lot of stuff on the plane, so might be useful as primary transport. I like the smallish toploaders for stuffing into luggage for local use. But you wouldn't need that with a standard shoulder bag or a sling.
Why Lowepro ... because they make excellent bags at reasonable prices. They temd to do the ergonomics better than Tamrac, according to my inspections of similar bags in the store, and to this discussion by a working pro:
http://www.bythom.com/bags.htm
http://letkeman.net/Photos
http://kimletkeman.blogspot.com
Hi woody
I have 3 that I use. One is an old Oyster 3000 which I got some years ago with my Minolta SLR kit and is great as it will also hold a flashgun and other stuff.
If just the S100fs is needed, I use a lowepro TLZ1.
If taking my DSLR etc as well as the S100fs, I use a biggish Nikon Kit bag which holds everything I have (except the tripod and monopod).
Pic here
Andy
i use a compact camcorder bag i got at walmart a few years ago - holds the s100 with flare guard thing, extra battery, extra sd card, a fuji z1 compact camera (for when the kids get bored at whatever event we're at and want to take some pictures), the user manual, and a lightscoop.
LowePro Nova 1 - S100fs fits v.snugly without the lens hood. Placing the camera side-ways (like a T rotated 90-anti-clockwise) , the lens hood can still rest in the "L" made by the camera's top profile.
n-0-0-b / f-3-1-d / S-1-0-0-f-s / F-Z-2-8 / K-2-0-0-D
I got the "official" Fujifilm bag made for the camera, the leather Fujifilm SC-FXS100.
I find that it is a really too small for the camera. I can get the camera in with the hood on backwards, but then stowing the camera strap becomes a problem. If I try to stuff the strap in the bag first and then place the camera, then the camera doesn't get into the bag deep enough for my liking.
Maybe I've just not played with the bag enough and it needs to be broken in like a leather shoe? The idea is great, just the size is too small. An inch or two extra on each side would have been great.
Anyone else have experience with the Fujifilm SC-FXS100?
Christopher
I prefer holster bags with four D-rings that can be worn on the chest with a special 4-point X-shaped belt. My reasons are
  • I need speedy access to the camera and accessories
  • I need the back free for a hiking bagpack or street bagpack
If I wasn't able to carry the cam in front of my chest, the remaining choices would boil down to either use a shoulder bag, a waist bag, or a photo bagpack. I have tried out dozens of bags of different kind and sizes, but nothing comes as close to the convenience as of carrying the camera in front and have the hiking stuff (clothes, water, victuals) on the back.
Thus I use exclusively
  • Lowepro Topload Zoom 1 (TLZ 1)
  • Lowepro Chest Harness
The TLZ1 is a perfect match for the S100FS and S200EXR with the original hood attached reverse (for the S200EXR you would have to buy it separatly from you local Fuji Service Center, as I did).
The front zippered pocket holds two spare batteries NP-140 (in a blue nylon B+W Filter etui, Size M), a MARUMI Super DHG Circular Polarizer 67mm in its box, a lipstick-style optical brush, and the original RR-80 remote release.
Carrying the camera the way I do, you would not even realise the additional load after a whole day of walking or hiking. With such a setup you can also master a fixed rope route or via ferrata, do canoeing, or other types of sport or activities.
Wolfram
Visit my private photo homepage:
http://www.daggochgryning.de
I'm very happy with my Lowepro Nova 170 AW (chestnut brown). It is very well made and holds my S100fs (facing downwards with extra large neoprene strap), lens hood, Sunpak 383 Super flashgun, Olympus TCON17, wide angle converter, Raynox 250, Cable release, 8 x ND filter and circular polarizer, extra batteries for camera and flash plus some memory cards and cleaning cloths. It has a built in waterproof cover and fits my equipment perfectly, nice and snug but everything has it's place and its all very accessable.
I swaped the Novas strap for the much more comfortable Lowepro Deluxe Shoulder Strap that I would recommend to anyone who values their shoulders :-)
http://products.lowepro.com/product/Deluxe-Shoulder-Strap,1926,41.htm
I used to have a Tamrac 614 Superpro (the original larger style) and my Nova is a revelation to carry around and I think it is better made than the Tamrac too.
Neil.
I am a bit of a bag junkie and I sometimes wonder if I am more interested in camera bags than the cameras.
One thing I have decided over the years is to keep the bag as small as possible. I use a big Lowpro shoulder bag for storage and transportation of my kit but I use small bags for days out.
At the moment I mostly use a British bag made by CCS called a Windsor for days out with my Fuji S5 plus 16-85. In the UK this bag is often sold as a bag for a Leica system. The bag is a Gladstone bag that holds itself open and is a traditional design. Very quirky but really very good. When had my D40 I could also get a 50mm or 55-200 in the bag but the S5 is too chunky for that
http://www.ccscentre.co.uk/
The other smaller company whose bags are excellent is Thinktank. I am going to try one of these next http://www.thinktankphoto.com/categories/shoulder-camera-bags.aspx
Other companies making interesting bags are Crumpler, Billingham and Kata
