Mary, field-of-view is the best way to express "reach". To try to
explain what "magnification" means would involve getting pedantic and
writing a book. Even after that, mag is rather worthless, IMO.
I DID explain that the OP's 10X camera did not have 10X
magnification...as did others.
This link helped me understand the difference between field of view
and magnification. Not sure why mag is worthless.
1) It's worthless because magnification is a RATIO...ie, it's 10X
bigger than something...and that something is seldom stated. Related
to photography, if we used magnification instead of focal length,
what would be the unstated reference? I suppose we could define the
"1X" FL to be 43mm for a FF 35mm format and extract 30 degree
horizontal FOV from that. In this way, any lens that gives a 30
degree horiz. FOV would be called a "1X" lens...regardless of the
actual FL. Isn't it obvious that calling it a 30 degree FOV lens is
just as good, if not better?
2) It's worthless because many people will be confused by "3X Zoom"
and a binocular with a stated 10-power.
Consider how
expensive the long telephotos are, there is no way they are the same
as the effective focal length on a crop camera. I've seen people
comment that buying an Olympus is better than a Nikon because you get
more telephoto with the lenses.
I'm confused by your above sentences? How does this relate to
"magnification"?
