Rich Jacobson
Leading Member
I would like to use the NRW RAW format of the P6000, and I have a couple of fundamental questions:
1) What is the difference between using RAW+JPEG at the time of capture compared to converting to JPEG either in camera or with Nikon View NX?
2) Although I am able to view the NRW files and convert to JPEG with View NX 1.2.0, I am unable to make any adjustments to the image with this software - not even exposure comp or white balance. I emailed Nikon Support with this issue, as these two adjustments are supposed to be available with .NRW files. Has anyone else had this problem? Again, if I just use ViewNX to view and convert to JPEG, what have I gained vs saving as JPEG to begin with?
3) I have found that viewing RAW files in PSE 5.0 (D40 NEF images) and the trial version of PSE 7 wirh ACR 5.1 can be painfully slow - in full screen mode it can take ten seconds to display a P6000 RAW image. View NX does this almost instantly. Is there a good solution which will allow me to organize and edit the NRW files which is faster than Elements 7? Since ACR 5.1 is not supported in the PSE5, I will be forced to buy new software anyway, so might as well evaluate the current options. Any suggestions?
