Iliah Borg
You get not noise, but poor luminance separation as luminance is largely based on green and muted colours.If you let other light colors
into the green pixels you get color noise.
Just muted colours, without good and natural colour transitions.If you let other light colors to red pixels you get color noise
Blue channel also affects luminance separation, but to lower extent then green; and same as red excessive transmittance results in muted colours.
What do you so? You create an algorithm to restore true greens (at the very least) hence gaining back luminance separation before demosaicing. There are other, more sophisticated methods to address the issue too.
Currently you can make a noise analysis separately for both green channels to see if one channel is more translucent then the other. Noise on the less translucent channel is higher because it enjoys more in-camera amplification (its effective ISO is lower)
http://www.libraw.org/
