Gondor
Leading Member
And when I measure the lenses from the photo the old lens seems to be 10% wider and not just 7
I quoted the "maximum diameter" specs from the vendors. On the Panny lens the IS switch seems to stick out, so it's probably included in the that maximum.And when I measure the lenses from the photo the old lens seems to be
10% wider
I measured the diameter on the jpg image as I mentioned and 10% seems accurateI quoted the "maximum diameter" specs from the vendors. On the PannyAnd when I measure the lenses from the photo the old lens seems to be
10% wider
the that maximum.
Erik
Not if the new Panny 14-45mm or 45-200 are any guide. They're mainlyBut a 18-200 starts at wide angle. One can make use of the shorter
backfocus to make design for the wide end lens configuration easier.
a little smaller in diameter than equivalent 4/3 or APS-C lenses.
Now it does wonders for the near-normal 20mm f/1.7 ...
Erik
The new lens, as Joe Bloggs pointed out, is effectively 20mm shorter than the new, because it sits that much closer to the sensor. The new design eliminates 20mm of optical "dead space" at the end of the lens.You see a "noticeable" difference in that photo? They are almostLooking at the review of G1 I think it is some difference and to
quote the comment in the review of the picture below: "The new
smaller lens mount and reduced flange back distance means that Micro
Four Thirds lenses are noticeable smaller than their conventional SLR
counterparts - even the already diminutive 14-42mm Olympus kit lens."
http://a.img-dpreview.com/previews/PanasonicG1/Images/features/lenses.jpg
exactly the same length. The new lens is a bit slimmer in diameter
though. If you compare the Panny 45-200 vs. the Sigma 55-200, the
Sigma is shorter and almost the same diameter.
"In general"?The new lens, as Joe Bloggs pointed out, is effectively 20mm shorter
lens.
But in general, for a zoom, there's not a substantial savings in lens
element width or overall length.
You wanted "fairly bright for low light shots and to enable me to control DOF". Making a slow zoom 1/3 stop wider (or whatever) won't make much of a difference in low light and DOF control, and it will make a difference in cost and size.Hehe, no of course not f/2.8
Mirror-less won't cut much if anything from the size of this lens. It's the long end that dictates overall size. The short end will be simpler. If anything the lens will be longer because you need about 25mm more extension than a DSLR lens to hit the longest focal length. Shorter backfocus helps with wide angles. That's why you can see a smaller package with lenses where most of the focal length range falls behind the backfocus of the DSLR. Such is the case with the 14-42mm: although it is about the same length as the 14-45mm, it's 20mm closer to the sensor so effectively 20mm shorter when mounted on the camera. This will be true to an even greater degree with ultrawide lenses.For example, I look at the Canon 18-200mm f/3.5-5.6. I would be
satisfied with slightly less range and if the lens was made for a
mirror less camera it should be able to shrink it given the same spec
or make it slightly faster.
Only when mounted - you can use a smaller never-ready case;-) In your bag, it takes up the same space and weight.The new lens, as Joe Bloggs pointed out, is effectively 20mm shorter
than the new,
What you gain on wides, you lose back on the teles. That's why the 45-200 is longer than the Sigma 55-200.The
lens.
How much incentive is there for Oly to make these lenses slimmer? No point in making them smaller than the outer mount diameter or they'll look odd.in a package much slimmer than the Oly lens pictured.
I count two tri-Elmars...."In general"?
When's the last time an interchangeable zoom lens has been made for a
mirrorless system of the same sensor size as an SLR system? The
Contax G 35-70mm?
Coz Leica sure don't make any for the M...
I thought the weight was less.Only when mounted - you can use a smaller never-ready case;-) In yourThe new lens, as Joe Bloggs pointed out, is effectively 20mm shorter
than the new,
This is true.What you gain on wides, you lose back on the teles. That's why theThe
lens.
Not to do something because it makes the camera "look odd"? Come on, Eric, this is Olympus we're talking about. Their 50mm macro is an awesome lens, but I still can't get over the concave front element. And, for God's sake, have you ever seen an E-300?How much incentive is there for Oly to make these lenses slimmer? Noin a package much slimmer than the Oly lens pictured.
look odd.
5g heavier. The Canon 18-55IS is also only 5g heavier than the Panny lens.I thought the weight was less.
Since the diameter difference is only 60 vs. 65mm, that means what? You can carry 6 lenses in the space of 5 assuming optimal packing and no padding in an odd-shaped flexible space?The length is more, but the volume is less. If the volume and the
weight are less, that should make it better in the bag.
I think the 50mm Macro and its concave front element look cool on my E-300 and E-330. I'd love to see tiny lenses on a flattop Olympus m4/3 camera. It would be totally awsome dude!Not to do something because it makes the camera "look odd"? Come on,How much incentive is there for Oly to make these lenses slimmer? No
look odd.
Fer sure...I think the 50mm Macro and its concave front element look cool on myNot to do something because it makes the camera "look odd"? Come on,How much incentive is there for Oly to make these lenses slimmer? No
look odd.
m4/3 camera. It would be totally awsome dude!![]()
I have an Olympus compact 35mm camera with a similar design. Though it might be three sections, not two. And the camera has a leather finished body.Leica style collapsible lenses. The camera has enough room so a short
portrait tele could store two sections of tube inside the camera, and
let you pull them out for shooting.
No. Chrome.Obviously, it should be brass...
Canon have been losing ground to Nikon in DSLR sales, so wether that will inspire them to make an EVIL I don't know. Nikons entry level DSLR dosn't even have LV.Canon could of course do it
but I doubt they will unless they are loosing market shares.
