--I made a pen tool selection of the upper shirt and moved it up above
the white clothing. I made a selection of the skin above the white
and moved it down. I then touched up with masking and cloning.
For the white showing through the shirt, I made a Color Range
selection of the white and lightest green and opened a green Solid
Color adjustment layer in darken mode.
Ronny
forgot to mention that I lassoed the area of concern without feathering because I just wanted to demonstrate what apply image does. Yes, it does turn green black, blue too( in darken mode). And you are right that you can create a mask to paint over it, but I just lowered the opacity of the layer, since I had made a selection.Hi GCam,
I want to be sure that I did the right thinig.
1. I duplicated the layer (I supposed there was a period after your
"dupe layer")
2. I went to image menu, chose "apply image". then chose the red
channel, and "substract" as the blending.
Then all the image turned black, except for the green shirt! Why???
(p.s. I know I can make a mask to apply the effect only on the part
of the shirt I want, and it works great, but I don't understand why
the green shirt was left intact and the rest of the image turnd black)
Second question : If the green shirt had been of another color, would
this method have worked? Would I have to choose another channel in
the image apply mode?
thank you for your answers!
--forgot to mention that I lassoed the area of concern withoutHi GCam,
"dupe layer")
