Having looked at the reviews on these 2 cameras and my own personal needs (portraits/landscapes) this is my view.
The D700 is best suited for Professionals who operate sometimes in low light, ie concerts and night time photography and need to push the sensor.
It is also very expensive if you want a long focal length as there is no crop factor.
Its not wise to use DX lenses as this will only give you approx 6mpx
Its not as high a resolution (in the center of an image) if you crop, this is because of pixel density.
D700 has larger viewfinder but smaller lcd panel (on top)
However it will answer most peoples needs if you are willing to spend £800 more (almost twice the price of the D300).
The D300 will only give as good IQ up to and including 800 ISO.
It has a greater selection of lenses available, at better value for money.
It gives you a crop factor which is an advantage only if you need long focul length.
The image quality is identical even at A3+
Its weighs less
Overall I am swaying towards the D300 for the above reasons. Tell me if my comments are accurate and any additional info between the two.
By no means am I saying these views are correct its just a summary of what I have seen in mags and on forums.
Ian
Its weighs less
Ian
