hey, that works great!! I didn't measure it scientifically but it's much faster than the normal continuous shooting. And it is such a easy method to switch between standard shooting & continuous shooting.
Hello guys,
If you want the higher than standard FPS without the vertical grip,
do the following:
First, make the following custom setting adjustments:
e5: Flash only
e6: Flash only
f4: Button press - Bracketing burst
f4: Button + dials - Bracketing mode
Quality to either JPG or RAW 12 bit. Set exposure manually. Activate
bracketing with the Fn + Command dial and set 9F (9 frames). Set your
shooting mode to single-shot (S). Do not use flash. Then hold the Fn
button and when you are ready to shoot, press the shutter release and
continue holding the Fn button. The camera will fire up to 9 frames
at 8 fps.
To continue shooting after 9 frames, you will need to let up on the
shutter release and depress it again. If you fire fewer than 9 shots,
you will only be able to shoot the remaining exposures in your
9-frame burst if you continue shooting again, without letting up on
the shutter release again.
Since you have set auto bracketing to apply only to flash, your
non-flash bracketing burst is fired at your manually set exposure —
it is not bracketed.
Have fun, it really works! No risk....
D700, 24-70 2.8, 70-300 VR, SB900
