I have a Kodak SLRn and was wondering if there is a specific nikon flash unit that works best with this SLR.
I tried the SB-25, SB-600, SB-800, and SB-30. Also tried the Metz 45 in the store. All of these flash units seem to either over-expose - I mean really over-expose where all you see is just a ghost image of the subject. The SB-800 underexposed to the point where I could almost not even see the image and it left me wondering if it even fired. I know that there is communication between the camera and flash as I can see the flash head move when I zoom the lens (24-85 or 17-35) and it recognizes the prime when I mount a 50mm f1.8. But the output is overkill in most cases when I use the flash in TTL or in "A" mode.
I tried the above flash units with the camera in Program mode as well as aperture priority and in Manual. Setting the camera to manual and setting the flash unit (SB-25) to manual results in a pretty good exposure. No complaints there. But once things go to "Auto" (P or A), everything goes downhill from there.
I also own the SLRc and use it with the Canon 580EX, 580EXII, and 220EX and don't have this issue. This seems a bit specific to the SLRn.
Is there a specific setting for flash use on the SLRn ?
What mode do you use for inddor shoe mount flash ?
What mode works best for outdoor fill flash ?
Is there a specific flash unit that works well with the SLRn ?
I would appreciate any help on the matter so that I can start using the SLRn for inddor shooting.
TY
TY
